[petsc-users] Solving with SNES
behzad baghapour
behzad.baghapour at gmail.com
Sat Nov 12 12:22:56 CST 2011
OK. My vision is made more clear.
So, after a line-search update in newton iteration, I should in some way
pass the updated values into my objects (elements) so that the FormJacobian
and FormFunctions use these objects for the next newton iteration. Then,
where is the proper place to do this?
On Sat, Nov 12, 2011 at 9:44 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Nov 12, 2011 at 12:10, behzad baghapour <
> behzad.baghapour at gmail.com> wrote:
>> Yes.The Roe average is a common method in this area.
>> I couldn't understand well what you said about stashing the quantities.
>> Each residual evaluation is proceeded by a Jacobian one if I choose an
>> Inexact Newton method and freeze Jacobian matrix for some Newton
>> iterations. Please make it for me more clear.
> As the FAQ discusses, the residual may be called multiple times before a
> Jacobian is needed, for example, in a line search. Also, some time
> integration methods (e.g. Rosenbrocks) will evaluate the residual several
> times before getting a new Jacobian. If it's free for you to stash these
> intermediate quantities during residual evaluation, then go ahead and do it
> (but don't forget that even if it's all computed, just putting it in memory
> costs something too). But make residual evaluation, not the monitor, the
> place where these intermediate quantities are computed and stored. The
> monitor is not called in the semantically correct place for this purpose.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111112/a62e7725/attachment-0001.htm>
