[petsc-users] Solving with SNES
    behzad baghapour
    behzad.baghapour at gmail.com
    Sat Nov 12 12:15:02 CST 2011
I am going to do this, however, for the next newton evaluation I should
update my context. I can,t find any command in petsc to do it for me. Upon
the previous discussion in this forum about SNES, I understood that a
monitor function is called after each newton iteration and when it is
called it may be a good chance to update my context within it.
I will appreciate any idea if there is a better way to do my job in this
matter.
On Sat, Nov 12, 2011 at 9:27 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Nov 12, 2011, at 2:08 AM, behzad baghapour wrote:
> > Dear developers,
> > I should pass a user-defined context, containing element and face local
> data obtained from PDE solution, to RHS and Jacobian evaluation of SNES
> process. Here I need to update my context each Newton Iteration. I may pass
> my context into a monitor function set by SNESMonitorSet. In the monitor
> function, I cast into my context and update my field (elements and faces)
> for next evaluations in RHS and Jacobian routines in Newton process.
>    Why don't you simply pass them in the SNESSetFunction() context and
> compute them inside your compute function, then use them. Also pass the
> same context into SNESSetJacobian() and you can reuse that information in
> computing in the Jacobian. I don't see any benefit in computing in the
> monitor function, that is not really the right place either practically or
> philosophically.
>   Barry
> > Please let me know, am I in right way?
> > Is there any better procedure in this matter?
> > Thanks, BB.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111112/7fc965b9/attachment.htm>
