[petsc-users] Solving with SNES
    Matthew Knepley
    knepley at gmail.com
    Sat Nov 12 12:01:49 CST 2011
On Sat, Nov 12, 2011 at 5:50 PM, behzad baghapour <
behzad.baghapour at gmail.com> wrote:
> So, I am solving the Euler equations (inviscid compressible flow) using
> discontinuous Galerkin method:
> M (dQ/dt) = R,
> R = nonlinear residual,
> M = mass matrix,
> Implicit procedure:
> F = M*(Q^(n+1)-Q^n)/DT - R,
> dF/dQ=J=M/DT-dR/dQ,
> Newton => Q^(n+1) = Q^n - (dF/dQ)^(-1) F ( with proper preconditioning )
> The nonlinear residual and Jacobian matrix are evaluated with a face-based
> method. Two integrals are involved (the effect of element internal
> connections and face flux connections). All of my calculations of flow
> states are solved and stored in arrays of objects called elements.So my
> residual and Derivative of residual routines are developed based on the
> element (and face) objects. Then it is better for me to keep them when
> using petsc as a nonlinear solver.
Pass your mesh data structure in using the ctx argument for your residual
and Jacobian evaluation routines.
   Matt
> Hope these make any help.
> Thanks,
> Behzad
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111112/e33b3806/attachment.htm>
