[petsc-users] questions
xiaohl
xiaohl at ices.utexas.edu
Fri Nov 11 12:06:59 CST 2011
Hi
I am going to use user defined context for this function call
DMDASetLocalFunction(da,(DMDALocalFunction1) FormFunctionLocal);
But How can I pass the "ctx" to the function FormFunctionLocal;
PetscErrorCode FormFunctionLocal(DMDALocalInfo *info, PetscScalar ***u,
PetscScalar ***f, void * ctx){
I look at the example
/petsc-3.2-p2/src/snes/examples/tutorials/ex19.c.html
I think you intialize the "user" context by
DMMGCreate(comm,nlevels,&user,&dmmg);
for DMMG
Do you have the similar routine for DMDA?
Hailong
On Wed, 2 Nov 2011 15:53:27 -0500, Barry Smith <bsmith at mcs.anl.gov>
wrote:
> On Nov 2, 2011, at 3:42 PM, Matthew Knepley wrote:
>> On Wed, Nov 2, 2011 at 8:38 PM, xiaohl <xiaohl at ices.utexas.edu>
>> wrote:
>> Hi
>> I am going to implement cell center difference method for
>> u = - K grad p
>> div u = f
>> where p is the pressure , u is the velocity, f is the source term.
>> my goal is to assemble the matrix and test the performance of
>> different linear solvers in parallel.
>> my question is how can I read the input file for K where K is n*n
>> tensor.
>> MatLoad()
> Hm, I think you should use a DMDA with n*n size dof and then use
> VecLoad() to load the entries of K.
> Barry
>> second one is that do you have any similar examples?
>> Nothing with the mixed-discretization of the Laplacian.
>> Matt
>> Hailong
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
