[petsc-users] RK substeps
Fri Nov 11 10:16:04 CST 2011
On Fri, Nov 11, 2011 at 09:52, Juha Jäykkä <juhaj at iki.fi> wrote:
> I have a large scale minimisation problem related to the problem I am using
> PETSc to solve. The PETSc code is independent, so I could have two PETSc's
> around and use the older one for TAO, but that seems like a lot of hassle
> without significant benefit.
You can use a pre-release version:
http://www.mcs.anl.gov/research/projects/tao/download/tao-2.0-beta7.tar.gz
As Matt says, some of the new PETSc nonlinear solvers can be used for
optimization, but if you have already written code for TAO, I would try
this version.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111111/fadd8493/attachment.htm>
