[petsc-users] RK substeps
Juha Jäykkä juhaj at iki.fi
Fri Nov 11 09:52:00 CST 2011
> What exactly are you using TAO to do?
I have a large scale minimisation problem related to the problem I am using
PETSc to solve. The PETSc code is independent, so I could have two PETSc's
around and use the older one for TAO, but that seems like a lot of hassle
without significant benefit.
I know the SNES module could be used as a substitute for TAO. At the moment, I
solve min(\int f(x)), where TAO needs the gradients of f(x); I could also
solve discrete grad(f(x))=0 with SNES, but as I then need compute the Jacobian
(=Hessian of f(x)), too, this has seemed to be too memory intensive to be
useful. I am not aware of a way around this.
-Juha
