[petsc-users] RK substeps
Juha Jäykkä
juhaj at iki.fi
Fri Nov 11 08:58:57 CST 2011
> We pass in the time of the stage when your RHSFunction is called. If you
Right, how can I have missed that?!? Thanks.
> haven't eliminated boundary conditions, your system is likely
> differential-algebraic, in which case you can use the IFunction interface
Eliminated? I am not sure what you mean. My boundaries are "periodic", but
thanks to the nature of my problem, they are periodic only up to a gauge
transformation. I need to perform that gauge transform at each time step.
I would be more than happy not to have to do that, but I cannot really see a
way out of it, so, if you have any ideas, I am very interested in hearing
them.
> improved in petsc-dev, so consider using it if you want the latest
Thanks for the tip, but I am stuck at 3.1 because I need TAO, too and it still
does not support 3.2.
Cheers,
Juha
