[petsc-users] Automatic partition of Cartesian grids
Matthew Knepley
knepley at gmail.com
Fri Nov 11 08:29:49 CST 2011
On Fri, Nov 11, 2011 at 2:26 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> I am currently using PETSc for my Fortran CFD code and I am manually
> partitioning my Cartesian grids. So in 2D, it will be something like
> u(1:size_x,jstart:jend), where the y component is partitioned into 2,4,8
> etc parts depending on the no. of processors.
> However, it seems that there are better ways to do it to get a more
> balanced load. Do I use DMDA in PETSc to do it? I'm now using staggered
> Cartesian grids for my u,v,p. Is there an example to construct a
> Laplace/Poisson equation using DMDA?
Yes use DMDA. Look at SNES ex5 and ex50.
> It is mentioned in the manual that DMMG infrastructure will be replaced in
> the next release and we should not use it. Is this related to DMDA?
Only if you use multigrid.
Matt
> Yours sincerely,
> TAY wee-beng
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111111/20c6e0a6/attachment.htm>
