[petsc-users] RK substeps
Jed Brown
jedbrown at mcs.anl.gov
Fri Nov 11 08:11:49 CST 2011
On Fri, Nov 11, 2011 at 08:07, Juha Jäykkä <juhaj at iki.fi> wrote:
> I was wondering if it is possible to access the internal TS/RK substep dt
> somehow? Apart from gleaning them from the source or Dormand&Prince, that
> is.
> In case I change the table, for example...
There is not an API. The TSRK implementation will be updated to accept a
user-provided table of coefficients like TSARKIMEX and TSROSW, but you
shouldn't need to access the coefficients except to view them, right?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111111/d5efc573/attachment.htm>
