[petsc-users] Small vectors and matrices
markus.sons at gmail.com markus.sons at gmail.com
Fri Nov 11 08:11:21 CST 2011
Thanks for the quick answer. We already have a wrapper class for
BLAS/Lapack and it's currently being used for small problems as well as
solving the - possibly huge - equation system.
We want to use PETSc to solve this problem in parallel and would have hoped
to be able to simultaneously drop the wrapper. I guess a mixed approach
would be perfect then?
On Fri, Nov 11, 2011 at 3:05 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Nov 11, 2011 at 03:35, markus.sons at gmail.com <
> markus.sons at gmail.com> wrote:
>> So, what do you recommend? Using PETSc for the large-scale computations
>> and some simple Vec and Mat class for small, local stuff?
> Don't use PETSc Mat/Vec for very small local problems like the 3x3 or 4x4
> matrices. If you are already addicted to templates and overloading, you
> might check out a library like Eigen which is competitive with BLAS/Lapack
> for some problems on some architectures.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111111/90fd099b/attachment.htm>
