[petsc-users] how to speed up convergence?
Thu Nov 10 11:20:53 CST 2011
On Thu, Nov 10, 2011 at 11:07, Konstantinos Kontzialis <
ckontzialis at lycos.com> wrote:
> 1. I use the conservative variables.
> 2. No limiter.
> 3. Boundary conditions are weakly imposed (to solve the riemann problem).
> 4. mat_fd_type ds is worse for the current case
It sounds like your system is poorly scaled. If you were consistent about
using PetscScalar in your code, then you can configure
--with-precision=__float128 and try that. It should remove the differencing
errors. It is very important to scale the system carefully when using
coloring or matrix-free finite differencing. It's a waste of time to dwell
on the other issues until you know that you have an accurate Jacobian.
> 5. sub_pc_type lu did a better work but not to a satisfactory level
In terms of time or iteration count? This test is for iteration count.
> 6. MATCOLORINGSL is used.
> For the preconditioner I need to do some changes.
> Please help me first to understand the coloring types in order to choose
> the best one (any web pages, links etc.?).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111110/c81d47a8/attachment.htm>
