[petsc-users] Changed output of VecView in 3.2
Manfred Gratt
manfred.gratt at uibk.ac.at
Thu Nov 10 06:14:03 CST 2011
Hello,
I am using petsc since 3.1 and upgraded my program to 3.2. I have now
the problem that the Vector output in ASCII has changed.
From only a list of numbers to the name of process that had the data
and then the numbers. Like this:
Vector Object: 2 MPI processes
type: mpi
Process [0]
0
0
0
Is there a option to change it back to only display numbers again?
I use this output only for a rough estimation if the solution is correct
and I don't want to rewrite the tool to check the correctness.
I use the viewer like this:
PetscViewer viewer;
PetscViewerASCIIOpen( PETSC_COMM_WORLD, solfname.c_str(), &viewer);
VecView( uT, viewer);
PetscViewerDestroy( &viewer);
Thanks
Manfred
