[petsc-users] How to use other matrix directly in petsc?
Bao Kai
paeanball at gmail.com
Thu Nov 10 02:00:08 CST 2011
Dear Hong and Matthew,
I looked at the interface file for umfpack, while I did not understand all
the things inside very clearly. I just began to read petsc manual three
days ago.
I guess the interface file is used to call the functions in umfpack to
solve the linear system. But the default matrix format in umfack should be
csc, and I did get how the interface handle this problem.
My matrix conversion problem is generally solved. The crucial point is that
you need to count the number of the non-zero entries in each row and use
that information to do the preallocation.
I go forward to try some linear solvers now.
The matrix generated with my problem is a little poor, resulting from a
mixed finite element method, asymmetric and indefinite. And the inclusion
of irregular boundary makes it worse. This is actually one reason I began
with a direct solver.
If you have any suggestions on solve this kinds of linear systems, please
tell me.
Thank you very much.
Best Regard,
Kai
> Message: 3
> Date: Wed, 9 Nov 2011 08:44:24 -0600
> From: Hong Zhang <hzhang at mcs.anl.gov>
> Subject: Re: [petsc-users] How to use other matrix directly in petsc?
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Message-ID:
> <CAGCphBsnmj0uvTnvcWvg=TCBiNhzuiBF8CAw1p3uKZjiyE7ySw at mail.gmail.com
> Content-Type: text/plain; charset=ISO-8859-1
> Bao:
> You may look at petsc-umfpack interface
> ~petsc/src/mat/impls/aij/seq/umfpack/umfpack.c
> It seems umfpack use csr format, same as petsc aij format.
> Hong
> > Dear all,
> > I have been writing a serial FEM code with a direct linear solver
> umfpack,
> > which is pretty easy to use. The problem is the memory required turned
> to be
> > very big and I can not afford it.
> > So I want to turn to PETSC to use ?some iterative solver.
> > I have written the the whole matrix assembly process with?coordinates
> list
> > format. The matrix can be converted to CSC format to use umfpack.
> > When I tried to use MatSetValues to generate the Matrix for petsc, it
> turned
> > out to be really slow.
> > I am wondering if there is some?efficient?way to convert the generated
> > matrix ( with COO, or CSC, or even CSR ) properly to make it usable for
> > PETSC.
> > Since the code at the moment is serial, the methods working for serial
> petsc
> > will be OK.
> > And I do many matrix manipulation( some may not easy with petsc) during
> the
> > matrix assembly, so I do not want to rewrite the whole assembling process
> > with petsc at the moment.
> > I just want to convert the matrix generated to the format the petsc can
> use.
> > It can save much time.
> > Best Regards,
> > Kai
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111110/dc547971/attachment.htm>
