[petsc-users] problem with -ts_type gl
Konstantinos Kontzialis
ckontzialis at lycos.com
Wed Nov 9 07:51:35 CST 2011
Dear all,
I run implicitly my code for the boundary layer over a flat plate, with:
mpiexec -n 1 valgrind ./hoac blasius -snes_mf_operator -llf_flux -n_out
10 -end_time 50 -implicit -pc_type bjacobi -sub_pc_type ilu
-sub_pc_factor_mat_ordering_type rcm -gl -ksp_type fgmres
-sub_pc_factor_levels 2 -snes_monitor -snes_converged_reason
-ksp_converged_reason -ts_view -ksp_pc_side right -sub_pc_factor_levels
4 -ksp_gmres_restart 500 -dt 1.0e-3 -snes_ksp_ew -ts_type gl
and I got:
Approximation order = 0
# DOF = 9600
# nodes in mesh = 1281
# elements in mesh = 1200
Navier-Stokes solution
Using LLF flux
Linear solve converged due to CONVERGED_RTOL iterations 1
Timestep 0: dt = 0.001, T = 0, Res[rho] = 2.06015e-10, Res[rhou] =
23.9721, Res[rhov] = 0.00322747, Res[E] = 0.00680121, CFL = 199.999
0 SNES Function norm 1.660837592895e+03
1 SNES Function norm 4.452765833604e+01
Linear solve converged due to CONVERGED_RTOL iterations 2
2 SNES Function norm 2.226427753100e+00
Linear solve converged due to CONVERGED_RTOL iterations 3
3 SNES Function norm 1.378423579772e-02
Linear solve converged due to CONVERGED_RTOL iterations 5
4 SNES Function norm 2.392525805814e-06
Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE
0 SNES Function norm 2.697720824971e+03
1 SNES Function norm 6.544960638431e+01
2 SNES Function norm 3.215472486217e+00
3 SNES Function norm 1.962042780514e-02
4 SNES Function norm 3.666057800237e-06
==2767== Jump to the invalid address stated on the next line
==2767== at 0x0: ???
==2767== by 0x585DB5E: TSGLChooseNextScheme (gl.c:795)
==2767== by 0x585F12A: TSSolve_GL (gl.c:948)
==2767== by 0x5881DD3: TSSolve (ts.c:1848)
==2767== by 0x4272CC: implicit_time (implicit_time.c:77)
==2767== by 0x4267B3: main (hoac.c:1175)
==2767== Address 0x0 is not stack'd, malloc'd or (recently) free'd
==2767==
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] TSGLAdaptChoose line 232
/home/kontzialis/petsc-3.2-p5/src/ts/impls/implicit/gl/gladapt.c
[0]PETSC ERROR: [0] TSGLChooseNextScheme line 774
/home/kontzialis/petsc-3.2-p5/src/ts/impls/implicit/gl/gl.c
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./hoac on a linux-gnu named PlusSodaL by kontzialis Wed
Nov 9 13:11:45 2011
[0]PETSC ERROR: Libraries linked from
/home/kontzialis/petsc-3.2-p5/linux-gnu-c-debug/lib
[0]PETSC ERROR: Configure run at Sat Nov 5 20:58:12 2011
[0]PETSC ERROR: Configure options --with-debugging=1
---with-mpi-dir=/usr/lib64/mpich2/bin --with-shared-libraries
--with-shared-libraries --with-large-file-io=1 --with-precision=double
--with-blacs=1 --download-blacs=yes --download-f-blas-lapack=yes
--with-plapack=1 --download-plapack=yes --with-scalapack=1
--download-scalapack=yes --with-superlu=1 --download-superlu=yes
--with-superlu_dist=1 --download-superlu_dist=yes --with-ml=1
--download-ml=yes --with-umfpack=1 --download-umfpack=yes --with-mpi=1
--download-mpich=1 --with-sundials=1 --download-sundials=1
--with-parmetis=1 --download-parmetis=1 --with-hypre=1 --download-hypre=1
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[cli_0]: aborting job:
==2767==
==2767== HEAP SUMMARY:
==2767== in use at exit: 10,732,979 bytes in 19,630 blocks
==2767== total heap usage: 53,585 allocs, 33,955 frees, 2,757,452,468
bytes allocated
==2767==
==2767== LEAK SUMMARY:
==2767== definitely lost: 1,114 bytes in 24 blocks
==2767== indirectly lost: 24 bytes in 3 blocks
==2767== possibly lost: 0 bytes in 0 blocks
==2767== still reachable: 10,731,841 bytes in 19,603 blocks
==2767== suppressed: 0 bytes in 0 blocks
==2767== Rerun with --leak-check=full to see details of leaked memory
What am I doing wrong?
Thank you,
Kostas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111109/60c8142e/attachment.htm>
