[petsc-users] compiling 3.2 on Windows
Tue Nov 8 16:16:49 CST 2011
On Tue, Nov 8, 2011 at 10:10 PM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> I tried to force using the - seemingly properly compiled - blas/lapack
> libs with:
> ./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release
> --with-x=0 --with-debugging=0 --with-cc='win32fe cl'
> --with-cxx='win32fe cl' --with-fc=0
> --with-mpi-dir=/cygdrive/c/mpich2-1.3.2p1-win-x86-64
> --with-hypre-dir=/cygdrive/c/pack/hypre-2.7.0b/src/hypre/
> --with-parmetis=1 --download-parmetis=1
> --with-blas-lib=/cygdrive/c/pack/petsc-3.2-p5/win64-msvc-release/lib/libf2cblas.lib
> --with-lapack-lib=/cygdrive/c/pack/petsc-3.2-p5/win64-msvc-release/lib/libf2clapack.lib
> I get the error:
>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> detail
> s):
> You set a value for --with-blas-lib=<lib> and --with-lapack-lib=<lib>, but
> ['/cy
> gdrive/c/pack/petsc-3.2-p5/win64-msvc-release/lib/libf2cblas.lib'] and
> ['/cygdri
> ve/c/pack/petsc-3.2-p5/win64-msvc-release/lib/libf2clapack.lib'] cannot be
> used
> Excerpt from configure.log:
> error LNK2019: unresolved external symbol dgetrs referenced in function
> main
> I will send complete log to petsc-maint again.
Send that and
'nm /cygdrive/c/pack/petsc-3.2-p5/win64-msvc-release/lib/libf2clapack.lib |
grep dgetrs'
If you look in configure.log, it shows you the stub source we use to check
the link and the
compile line. You can easily test yourself.
    Matt
Any more hints?
> Thanks,
> Dominik
> On Mon, Nov 7, 2011 at 3:57 PM, Dominik Szczerba <dominik at itis.ethz.ch>
> wrote:
> > I am configuring with:
> > --with-cxx='win32fe cl' --with-fc=0 --download-f2cblaslapack
> > and getting an error:
> > for details):
> > --download-f2cblaslapack libraries cannot be used
> >  File "./config/configure.py", line 283, in petsc_configure
> >    framework.configure(out = sys.stdout)
> >  File
> "/cygdrive/c/pack/petsc-3.2-p5/config/BuildSystem/config/framework.py",
> > line 925, in configure
> >    child.configure()
> >  File
> "/cygdrive/c/pack/petsc-3.2-p5/config/BuildSystem/config/packages/BlasLapack.py",
> > line 538, in configure
> >    self.executeTest(self.configureLibrary)
> >  File "/cygdrive/c/pack/petsc-3.2-p5/config/BuildSystem/config/base.py",
> > line 115, in executeTest
> >    ret = apply(test, args,kargs)
> >  File
> > line 444, in configureLibrary
> >    for (name, blasLibrary, lapackLibrary, self.useCompatibilityLibs)
> > in self.generateGuesses():
> >  File
> > line 162, in generateGuesses
> >    raise RuntimeError('--download-f2cblaslapack libraries cannot be
> used')
> > I will send the full log to petsc-maint in a second. How do I go from
> here?
> > Thanks for any hints,
> > Dominik
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111108/639eacaf/attachment.htm>
