[petsc-users] About efficiency in MatAssembling
PEREZ CERQUERA MANUEL RICARDO
manuel.perezcerquera at polito.it
Tue Nov 8 07:49:37 CST 2011
Hi all,
I'm having problems with the efficiency of my code, I
mean, it's taken so much time when I'm running in 2
processors than in 1 Processor. My guess is that the
communications at low level inside PETSC Directives,
because I'm generating the elements on wrong processes and
this is killing me, moreover I'm over estimated my memory
occupancy, so my questions are:
1. For The Memory Occupancy , I Know the NonZero Pattern
of my Matrix, so I'm calling
CALL
MatCreateMPIAIJ(PETSC_COMM_WORLD,LocalNOfBEMFunctions,LocalTotalRank,NOfTotalBEMFunctions,GlobalTotalRank,&
PETSC_NULL_INTEGER,NNZ_diagonal(:),&
PETSC_NULL_INTEGER,NNZ_outofdiagonal(:),UFar,ierr)
So I have a doubt if when I'm doing this Should I
specify just one NNZ_diagonal(:) or NNZ_outofdiagonal(:)
?, not both of them as I'm doing.
2. For the time efficiency, When I'm calling,
MatSetValues() The Global Index is out of the range set in
MatCreateMPIAIJ, I mean for example if the range is
between 1 and 10 in a Matrix of 100 The Global index are
let's say 1 20 25 2 5 60 85 90 100 3 so there are some
elements out of the range, moreover I ran with -info
option and I got this:
[0] MatAssemblyBegin_MPIAIJ(): Stash has 84088 entries,
uses 3 mallocs. And in the manual is written this actually
means I'm generating entries in the wrong process,not
because of the mollocs but because of the entries, Do I'm
right ?
So is this indeed not efficient?. If not, Can you
suggest me a possible way to improve it? , Or there are
some special way for indexing the elements in order to put
them in order to solve the system?
Thanks!
Manuel.
I realized with -info option in run time
Eng. Manuel Ricardo Perez Cerquera. MSc. Ph.D student
Antenna and EMC Lab (LACE)
Istituto Superiore Mario Boella (ISMB)
Politecnico di Torino
Via Pier Carlo Boggio 61, Torino 10138, Italy
Email: manuel.perezcerquera at polito.it
Phone: +39 0112276704
Fax: +39 011 2276 299
