[petsc-users] MPI_AllReduce vs VecScatterCreateToAll
Tue Nov 8 06:56:18 CST 2011
You shouldn't see timeouts. Sounds like a misconfiguration or a bug in the
code. If you want an MPI_Allreduce, then MPI_Allreduce is the best way to
get it. VecScatter is intended for less structured operations.
On Nov 7, 2011 10:42 PM, "Robert Ellis" <Robert.Ellis at geosoft.com> wrote:
>  Hello Petsc Developers,****
> I have a predominantly Petsc application but for simplicity it uses a very
> few MPI_AllReduce calls. I am finding that the MPI_AllReduce operations are
> sometimes causing problems (appears to be semaphore time outs) if the
> interprocess communication is slow. I never have any problem with the Petsc
> operations. Is it reasonable that Petsc would be more robust that
> MPI_AllReduce?****
> Also, is the VecScatterCreateToAll set of operations the best way to
> replace the MPI_AllReduce?****
> Thanks for any advice,****
> Rob****
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111108/df47c7cc/attachment.htm>
