[petsc-users] Use two KSP solver in the same code.
Mon Nov 7 11:32:14 CST 2011
On Mon, 7 Nov 2011, Alexander Grayver wrote:
> On 07.11.2011 17:47, Jed Brown wrote:
> > On Mon, Nov 7, 2011 at 09:39, NAN ZHAO <zhaonanavril at gmail.com
> > <mailto:zhaonanavril at gmail.com>> wrote:
> >     I want to solve a coupled system and prepare to solve the two
> >     system in certain order in one code. I need to use the KSP solver
> >     twice, Does anyone know a good example in the example file. Do I
> >     need to create two Petsc object in a c++ code?
> > Just create two KSP objects, one for each system you want to solve.
> Sorry for disturbing, but I've also got similar question. How can one specify
> individual options through command line for two different KSPs?
Use:
KSPSetOptionsPrefix(ksp1, "solver1_")
KSPSetOptionsPrefix(ksp1, "solver2_")
Now - you can specify stuff like:
-solver1_ksp_type gmres -solver2_ksp_type cg
Satish
