[petsc-users] [petsc-maint #95802] Re: compiling 3.2 on Windows
Satish Balay
petsc-maint at mcs.anl.gov
Mon Nov 7 11:29:05 CST 2011
I just attempted a build on windows with petsc-3.2 and MS compilers [64bit] - and
couldn't reproduce this problem.
$ ./configure --with-cc='win32fe cl' --with-fc=0 --download-f2cblaslapack=1 PETSC_ARCH=arch-mswin64
I'm not sure why this isn't working for you. What do you get for:
$ dumpbin.exe /SYMBOLS libf2cblas.lib |grep ddot
I see - for my build:
balay at bucharest ~/petsc-3.2-p5/arch-mswin64/lib
00A 00000000 SECT4 notype () External | ddot_
00D 00000000 SECT5 notype Static | $pdata$ddot_
010 00000000 SECT6 notype Static | $unwind$ddot_
014 00000004 SECT7 notype Static | ?mp1@?1??ddot_@@9 at 9 (`ddot_'::`2'::mp1)
016 00000010 SECT7 notype Static | ?m@?1??ddot_@@9 at 9 (`ddot_'::`2'::m)
018 00000014 SECT7 notype Static | ?i__@?1??ddot_@@9 at 9 (`ddot_'::`2'::i__)
019 00000000 SECT7 notype Static | ?iy@?1??ddot_@@9 at 9 (`ddot_'::`2'::iy)
01A 00000018 SECT7 notype Static | ?ix@?1??ddot_@@9 at 9 (`ddot_'::`2'::ix)
01B 00000008 SECT7 notype Static | ?dtemp@?1??ddot_@@9 at 9 (`ddot_'::`2'::dtemp)
Satish
On Mon, 7 Nov 2011, Dominik Szczerba wrote:
> Sorry, seems I am wrong, dumpbin.exe says it is valid:
> Any more hints are appreciated.
> Dominik
> C:\pack\petsc-3.2-p5\win64-msvc-release\lib>dumpbin libf2cblas.lib
> Microsoft (R) COFF/PE Dumper Version 10.00.40219.01
> Copyright (C) Microsoft Corporation. All rights reserved.
> Dump of file libf2cblas.lib
> File Type: LIBRARY
> Summary
> 1668 .bss
> 12E2 .data
> 5370 .debug$S
> 1CD3 .drectve
> 17F4 .pdata
> BD3 .rdata
> 5B191 .text
> 2A18 .xdata
> On Mon, Nov 7, 2011 at 4:17 PM, Dominik Szczerba <dominik at itis.ethz.ch> wrote:
> > I think I know what the reason is. blas/lapack seems to be linked on
> > cygwin as a cygwin library while I need a native Windows library, like
> > I am doing with hypre. Is there a way to go here or do I need to (and
> > actually can) setup blas/lapack myself? Will it also happen with
> > parmetis? Note, parmetis and blas/lapack used to compile fine natively
> > some time ago.
> > Dominik
> > On Mon, Nov 7, 2011 at 3:57 PM, Dominik Szczerba <dominik at itis.ethz.ch> wrote:
> >> I am configuring with:
> >> ./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release
> >> --with-x=0 --with-debugging=0 --with-cc='win32fe cl'
> >> --with-cxx='win32fe cl' --with-fc=0 --download-f2cblaslapack
> >> --with-mpi-dir=/cygdrive/c/mpich2-1.3.2p1-win-x86-64
> >> --with-hypre-dir=/cygdrive/c/pack/hypre-2.7.0b/src/hypre/
> >> --with-parmetis=1 --download-parmetis=1
> >> and getting an error:
> >> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
> >> for details):
> >> --download-f2cblaslapack libraries cannot be used
> >> File "./config/configure.py", line 283, in petsc_configure
> >> framework.configure(out = sys.stdout)
> >> File "/cygdrive/c/pack/petsc-3.2-p5/config/BuildSystem/config/framework.py",
> >> line 925, in configure
> >> child.configure()
> >> File "/cygdrive/c/pack/petsc-3.2-p5/config/BuildSystem/config/packages/BlasLapack.py",
> >> line 538, in configure
> >> self.executeTest(self.configureLibrary)
> >> File "/cygdrive/c/pack/petsc-3.2-p5/config/BuildSystem/config/base.py",
> >> line 115, in executeTest
> >> ret = apply(test, args,kargs)
> >> line 444, in configureLibrary
> >> for (name, blasLibrary, lapackLibrary, self.useCompatibilityLibs)
> >> in self.generateGuesses():
> >> line 162, in generateGuesses
> >> raise RuntimeError('--download-f2cblaslapack libraries cannot be used')
> >> I will send the full log to petsc-maint in a second. How do I go from here?
> >> Thanks for any hints,
> >> Dominik
