[petsc-users] Use two KSP solver in the same code.
Matthew Knepley
knepley at gmail.com
Mon Nov 7 10:45:38 CST 2011
On Mon, Nov 7, 2011 at 4:39 PM, NAN ZHAO <zhaonanavril at gmail.com> wrote:
> Hi all,
> I want to solve a coupled system and prepare to solve the two system in
> certain order in one code. I need to use the KSP solver twice, Does anyone
> know a good example in the example file. Do I need to create two Petsc
> object in a c++ code?
If you want to solve the same system twice, call KSPSolve() twice. If you
want to solve two different systems, make
two KSPs. If you absolutely must reuse the allocated space for Krylov
vectors or something like that, call KSPSetOperators()
again and KSPSolve() again.
Matt
> Thanks,
> Nan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111107/4b5e0f4b/attachment-0001.htm>
