[petsc-users] compiling 3.2 on Windows
Dominik Szczerba dominik at itis.ethz.ch
Mon Nov 7 09:17:57 CST 2011
I think I know what the reason is. blas/lapack seems to be linked on
cygwin as a cygwin library while I need a native Windows library, like
I am doing with hypre. Is there a way to go here or do I need to (and
actually can) setup blas/lapack myself? Will it also happen with
parmetis? Note, parmetis and blas/lapack used to compile fine natively
some time ago.
Dominik
On Mon, Nov 7, 2011 at 3:57 PM, Dominik Szczerba <dominik at itis.ethz.ch> wrote:
> I am configuring with:
> ./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release
> --with-x=0 --with-debugging=0 --with-cc='win32fe cl'
> --with-cxx='win32fe cl' --with-fc=0 --download-f2cblaslapack
> --with-mpi-dir=/cygdrive/c/mpich2-1.3.2p1-win-x86-64
> --with-hypre-dir=/cygdrive/c/pack/hypre-2.7.0b/src/hypre/
> --with-parmetis=1 --download-parmetis=1
> and getting an error:
>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for details):
> --download-f2cblaslapack libraries cannot be used
>  File "./config/configure.py", line 283, in petsc_configure
>    framework.configure(out = sys.stdout)
>  File "/cygdrive/c/pack/petsc-3.2-p5/config/BuildSystem/config/framework.py",
> line 925, in configure
>    child.configure()
>  File "/cygdrive/c/pack/petsc-3.2-p5/config/BuildSystem/config/packages/BlasLapack.py",
> line 538, in configure
>    self.executeTest(self.configureLibrary)
>  File "/cygdrive/c/pack/petsc-3.2-p5/config/BuildSystem/config/base.py",
> line 115, in executeTest
>    ret = apply(test, args,kargs)
> line 444, in configureLibrary
>    for (name, blasLibrary, lapackLibrary, self.useCompatibilityLibs)
> in self.generateGuesses():
> line 162, in generateGuesses
>    raise RuntimeError('--download-f2cblaslapack libraries cannot be used')
> I will send the full log to petsc-maint in a second. How do I go from here?
> Thanks for any hints,
> Dominik
