[petsc-users] possible development on Windows?
Alexander Grayver agrayver at gfz-potsdam.de
Mon Nov 7 04:30:15 CST 2011
Hi Dominik,
I'm running Windows 7 Professional. I still use only local debugging
(i.e. I run several MPI processes, but on the local machine), so I don't
need Windows HPC. Since I work with IFC, it is a bit tricky for me and
I'm not sure that you should follow same ugly way. What I do is to run
several processes with mpiexec in suspended mode, then attach to them
from VS Debugger and debug. With MPI Debugger installed you can easily
switch among several processes. Using C/C++ you better first try to
follow MS guidelines, e.g.:
http://www.danielmoth.com/Blog/MPI-Cluster-Debugger-Launch-Integration-In-VS2010.aspx
Alexander
On 06.11.2011 20:10, Dominik Szczerba wrote:
> Hi Alexander,
> Are you running Windows HPC edition? According to google, it is
> required for the referred MPI Cluster Debugger.
> I would also appreciate some more hints on "and something else", if
> you have them.
> Many thanks,
> Dominik
> On Sun, Nov 6, 2011 at 3:55 PM, Alexander Grayver
> <agrayver at gfz-potsdam.de>  wrote:
>> Hi,
>> I work with Petsc both under Linux and Windows.
>> I develop in Fortran and it makes things even more tricky sometimes. My
>> compilers are those included in VS 2008 and IFC 12 + MKL's BLAS/LAPACK for
>> Fortran (however I started to work with petsc using IFC 10.1 and downloaded
>> BLAS/LAPACK using petsc configure options).
>> The most tricky part for me was to build petsc properly, although all
>> problems are directly and indirectly related to the Fortran usage. So if you
>> write in C/C++ I would say it's going to be easy for you. Anyway I can share
>> my configuration line if you get some problems.
>> I use VS IDE and debug applications in it. For sequential programs it is no
>> problems, for MPI you have to install some additional tools (MPI Cluster
>> Debugger and something else) and just switch debugger type from VS whenever
>> you want. To make this debugger working with IFC cost me a couple of days
>> and a lot of googling, but again for C/C++ it should be easy.
>> Unfortunately, there are no things like valgrind for Windows. I couldn't
>> find at least.
>> Regards,
>> Alexander
>> On 06.11.2011 11:43, Dominik Szczerba wrote:
>>> I am normally working and developing my codes on linux, only compiling
>>> them at the end for Windows, but need to evaluate the possibilities to
>>> also efficiently develop on Windows. Is anyone developing Petsc based
>>> applications on Windows and could share some experiences? In
>>> particular, is it possible to debug only on Cygwin's gdb port or also
>>> to use (somehow) the Visual Studio's built in debugger? Are there
>>> tools comparable to valgrind to detect MPI-aware illegal memory
>>> accesses and leaks? I heard about TotalView, but never worked with it.
>>> Thanks for any thoughts,
>>> Dominik
