[petsc-users] help for beginner :-)
robert
robert.bodner at unil.ch
Sun Nov 6 07:28:38 CST 2011
> Diffusion is as "nice" as possible in terms of stability and
> well-established theory, multigrid will normally work very well. In
> the latest release of PETSc, you could try -pc_type gamg.
> Otherwise/alternatively, configure using --download-ml or
> --download-hypre, then run with -pc_type ml or -pc_type hypre.
Thanks for your reply.
Do you have experience with lumping of the mass matrix?
The following options semm to work fine if I don't use lumping:
mpiexec -np 4 ./ThermoPaine3d-opt -ksp_type fgmres -pc_type ksp
-ksp_ksp_type cg -ksp_pc_type jacobi -ksp_monitor_true_residual
-ksp_converged_reason
(any comments to the options???)
However, for heat diffusion, especially for non-steady starting
conditions, oscillations seem to be a common problem (AFAIK).
If I apply lumping of the mass matrix - which means I put the row-sum of
the mass matrix on the main diagonal - the solver doesn't converge any
more. Before it converged after 2 to 5 iterations, now I was running
several hundreds.
Maybe some of you - definitely more experienced users - have some
ideas/suggestions?
P.S.: I have tried a lot of different combinations of solvers and
preconditioners (including those of the last reply)..
Thank you,
Robert
