[petsc-users] Jacobian free in SNES
Konstantinos Kontzialis
ckontzialis at lycos.com
Sat Nov 5 14:40:19 CDT 2011
Dear all,
I upgraded to version 3.2. However, I still have some problems:
I code the following:
ierr = TSCreate(sys.comm, &sys.ts);
CHKERRQ(ierr);
ierr = TSSetSolution(sys.ts, sys.gsv);
CHKERRQ(ierr);
ierr = TSSetIFunction(sys.ts, sys.gres0,
base_residual_implicit, &sys);
CHKERRQ(ierr);
ISColoring iscoloring;
MatFDColoring fdcoloring;
ierr = jacobian_diff_numerical(sys, &sys.P);
CHKERRQ(ierr);
ierr = MatGetColoring(sys.P, MATCOLORINGSL, &iscoloring);
CHKERRQ(ierr);
ierr = MatFDColoringCreate(sys.P, iscoloring, &fdcoloring);
CHKERRQ(ierr);
ierr = MatFDColoringSetFunction(fdcoloring, base_residual_implicit,
&sys);
CHKERRQ(ierr);
ierr = TSSetInitialTimeStep(sys.ts, sys.con->tm, sys.con->dt);
CHKERRQ(ierr);
ierr = TSSetDuration(sys.ts, 100e+6, sys.con->etime);
CHKERRQ(ierr);
ierr = TSSetFromOptions(sys.ts);
CHKERRQ(ierr);
ierr = TSSetUp(sys.ts);
CHKERRQ(ierr);
ierr = TSGetSNES(sys.ts, &sys.snes);
CHKERRQ(ierr);
ierr = MatCreateSNESMF(sys.snes, &sys.J);
CHKERRQ(ierr);
ierr = SNESSetJacobian(sys.snes, sys.J, sys.P,
SNESDefaultComputeJacobianColor, fdcoloring);
CHKERRQ(ierr);
ierr = TSView(sys.ts, PETSC_VIEWER_STDOUT_WORLD);
CHKERRQ(ierr);
i = 10000;
ierr = TSStep(sys.ts);
CHKERRQ(ierr);
I run with:
mpiexec -n 8 valgrind ./hoac cylinder -llf_flux -n_out 5 -end_time
10000.0 -explicit -explicit_type 2 -ts_type beuler -pc_type asm
-ksp_right_pc -sub_pc_type ilu -sub_pc_factor_mat_ordering_type rcm
1.0e-8 -gl -sub_pc_factor_levels 2 -dt 2.0e-1 -snes_monitor -snes_stol
1.0e-50 -snes_ksp_ew -snes_ls_maxstep 10.0 -snes_stol 1.0e-50
-snes_max_linear_solve_fail 50 -snes_max_fail 50
-ksp_monitor_true_residual -snes_mf_operator
and I get:
METIS 4.0.3 Copyright 1998, Regents of the University of Minnesota
Graph Information ---------------------------------------------------
Name: mesh.graph, #Vertices: 400, #Edges: 780, #Parts: 8
Recursive Partitioning... -------------------------------------------
8-way Edge-Cut: 102, Balance: 1.00
Timing Information --------------------------------------------------
I/O: 0.000
Partitioning: 0.000 (PMETIS time)
Total: 0.000
Approximation order = 1
# DOF = 6080
# nodes in mesh = 400
# elements in mesh = 380
Euler solution
Using LLF flux
0 KSP preconditioned resid norm 4.015618492963e+01 true resid norm
2.209663952405e+02 ||r(i)||/||b|| 1.000000000000e+00
1 KSP preconditioned resid norm 4.431081191507e-14 true resid norm
2.384009492855e-13 ||r(i)||/||b|| 1.078901382384e-15
TS Object: 8 MPI processes
type: beuler
maximum steps=100000000
maximum time=10000
total number of nonlinear solver iterations=0
total number of nonlinear solve failures=0
total number of linear solver iterations=0
total number of rejected steps=0
SNES Object: 8 MPI processes
type: ls
line search variant: SNESLineSearchCubic
alpha=1.000000000000e-04, maxstep=1.000000000000e+01,
minlambda=1.000000000000e-12
maximum iterations=50, maximum function evaluations=10000
tolerances: relative=1e-08, absolute=1e-50, solution=1e-50
total number of function evaluations=0
Eisenstat-Walker computation of KSP relative tolerance (version 2)
rtol_0=0.3, rtol_max=0.9, threshold=0.1
gamma=1, alpha=1.61803, alpha2=1.61803
KSP Object: 8 MPI processes
type: gmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
left preconditioning
using DEFAULT norm type for convergence test
PC Object: 8 MPI processes
type: asm
Additive Schwarz: total subdomain blocks not yet set, amount of
overlap = 1
Additive Schwarz: restriction/interpolation type - RESTRICT
linear system matrix:
Matrix Object: 8 MPI processes
type: mffd
rows=6080, cols=6080
matrix-free approximation:
err=1e-07 (relative error in function evaluation)
The compute h routine has not yet been set
0 SNES Function norm 2.822902692891e-01
==25984== Invalid read of size 4
==25981== Invalid read of size 4
==25981== at 0x4FC73CD: MatMult (matrix.c:2157)
==25981== by 0x406BD3: base_residual_implicit
(base_residual_implicit.c:29)
==25981== by 0x50597C2: MatFDColoringApply_BAIJ (baij.c:2815)
==25981== by 0x5022C69: MatFDColoringApply (fdmatrix.c:517)
==25981== by 0x57D2E9B: SNESDefaultComputeJacobianColor (snesj2.c:48)
==25981== by 0x57B7852: SNESComputeJacobian (snes.c:1357)
==25981== by 0x57FAEF8: SNESSolve_LS (ls.c:188)
==25981== by 0x57C43AA: SNESSolve (snes.c:2676)
==25981== by 0x58694E1: TSStep_Theta (theta.c:41)
==25981== by 0x58812D6: TSStep (ts.c:1776)
==25981== by 0x4208A5: explicit_time (explicit_time.c:148)
==25981== by 0x429E14: main (hoac.c:1250)
==25981== Address 0xe800000000b84400 is not stack'd, malloc'd or
(recently) free'd
==25981==
==25984== at 0x4FC73CD: MatMult (matrix.c:2157)
==25984== by 0x406BD3: base_residual_implicit
==25984== by 0x50597C2: MatFDColoringApply_BAIJ (baij.c:2815)
==25984== by 0x5022C69: MatFDColoringApply (fdmatrix.c:517)
==25984== by 0x57D2E9B: SNESDefaultComputeJacobianColor (snesj2.c:48)
==25984== by 0x57B7852: SNESComputeJacobian (snes.c:1357)
==25984== by 0x57FAEF8: SNESSolve_LS (ls.c:188)
==25984== by 0x57C43AA: SNESSolve (snes.c:2676)
==25984== by 0x58694E1: TSStep_Theta (theta.c:41)
==25984== by 0x58812D6: TSStep (ts.c:1776)
==25984== by 0x4208A5: explicit_time (explicit_time.c:148)
==25984== by 0x429E14: main (hoac.c:1250)
==25984== Address 0xe800000000b84400 is not stack'd, malloc'd or
(recently) free'd
==25984==
==25983== Invalid read of size 4
==25983== at 0x4FC73CD: MatMult (matrix.c:2157)
==25983== by 0x406BD3: base_residual_implicit
==25983== by 0x50597C2: MatFDColoringApply_BAIJ (baij.c:2815)
==25983== by 0x5022C69: MatFDColoringApply (fdmatrix.c:517)
==25983== by 0x57D2E9B: SNESDefaultComputeJacobianColor (snesj2.c:48)
==25983== by 0x57B7852: SNESComputeJacobian (snes.c:1357)
==25983== by 0x57FAEF8: SNESSolve_LS (ls.c:188)
==25983== by 0x57C43AA: SNESSolve (snes.c:2676)
==25983== by 0x58694E1: TSStep_Theta (theta.c:41)
==25983== by 0x58812D6: TSStep (ts.c:1776)
==25983== by 0x4208A5: explicit_time (explicit_time.c:148)
==25983== by 0x429E14: main (hoac.c:1250)
==25983== Address 0xe800000000b84400 is not stack'd, malloc'd or
(recently) free'd
==25983==
==25979== Invalid read of size 4
==25979== at 0x4FC73CD: MatMult (matrix.c:2157)
==25979== by 0x406BD3: base_residual_implicit
==25979== by 0x50597C2: MatFDColoringApply_BAIJ (baij.c:2815)
==25978== Invalid read of size 4
==25978== at 0x4FC73CD: MatMult (matrix.c:2157)
==25982== Invalid read of size 4
==25982== at 0x4FC73CD: MatMult (matrix.c:2157)
==25982== by 0x406BD3: base_residual_implicit
==25978== by 0x406BD3: base_residual_implicit
==25978== by 0x50597C2: MatFDColoringApply_BAIJ (baij.c:2815)
==25978== by 0x5022C69: MatFDColoringApply (fdmatrix.c:517)
==25978== by 0x57D2E9B: SNESDefaultComputeJacobianColor (snesj2.c:48)
==25982== by 0x50597C2: MatFDColoringApply_BAIJ (baij.c:2815)
==25982== by 0x5022C69: MatFDColoringApply (fdmatrix.c:517)
==25982== by 0x57D2E9B: SNESDefaultComputeJacobianColor (snesj2.c:48)
==25982== by 0x57B7852: SNESComputeJacobian (snes.c:1357)
==25978== by 0x57B7852: SNESComputeJacobian (snes.c:1357)
==25978== by 0x57FAEF8: SNESSolve_LS (ls.c:188)
==25978== by 0x57C43AA: SNESSolve (snes.c:2676)
==25982== by 0x57FAEF8: SNESSolve_LS (ls.c:188)
==25982== by 0x57C43AA: SNESSolve (snes.c:2676)
==25982== by 0x58694E1: TSStep_Theta (theta.c:41)
==25978== by 0x58694E1: TSStep_Theta (theta.c:41)
==25978== by 0x58812D6: TSStep (ts.c:1776)
==25978== by 0x4208A5: explicit_time (explicit_time.c:148)
==25982== by 0x58812D6: TSStep (ts.c:1776)
==25982== by 0x4208A5: explicit_time (explicit_time.c:148)
==25982== by 0x429E14: main (hoac.c:1250)
==25982== Address 0xe800000000b84400 is not stack'd, malloc'd or
(recently) free'd
==25978== by 0x429E14: main (hoac.c:1250)
==25978== Address 0xe800000000b84400 is not stack'd, malloc'd or
(recently) free'd
==25978==
==25982==
==25979== by 0x5022C69: MatFDColoringApply (fdmatrix.c:517)
==25979== by 0x57D2E9B: SNESDefaultComputeJacobianColor (snesj2.c:48)
==25979== by 0x57B7852: SNESComputeJacobian (snes.c:1357)
==25979== by 0x57FAEF8: SNESSolve_LS (ls.c:188)
==25979== by 0x57C43AA: SNESSolve (snes.c:2676)
==25979== by 0x58694E1: TSStep_Theta (theta.c:41)
==25979== by 0x58812D6: TSStep (ts.c:1776)
==25979== by 0x4208A5: explicit_time (explicit_time.c:148)
==25979== by 0x429E14: main (hoac.c:1250)
==25979== Address 0xe800000000b84400 is not stack'd, malloc'd or
(recently) free'd
==25979==
==25977== Invalid read of size 4
==25977== at 0x4FC73CD: MatMult (matrix.c:2157)
==25977== by 0x406BD3: base_residual_implicit
==25977== by 0x50597C2: MatFDColoringApply_BAIJ (baij.c:2815)
==25977== by 0x5022C69: MatFDColoringApply (fdmatrix.c:517)
==25977== by 0x57D2E9B: SNESDefaultComputeJacobianColor (snesj2.c:48)
==25977== by 0x57B7852: SNESComputeJacobian (snes.c:1357)
==25977== by 0x57FAEF8: SNESSolve_LS (ls.c:188)
==25977== by 0x57C43AA: SNESSolve (snes.c:2676)
==25977== by 0x58694E1: TSStep_Theta (theta.c:41)
==25977== by 0x58812D6: TSStep (ts.c:1776)
==25977== by 0x4208A5: explicit_time (explicit_time.c:148)
==25977== by 0x429E14: main (hoac.c:1250)
==25977== Address 0xe800000000b84400 is not stack'd, malloc'd or
(recently) free'd
==25977==
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[0]PETSC
ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
find memory corruption errors
==25980== Invalid read of size 4
==25980== at 0x4FC73CD: MatMult (matrix.c:2157)
==25980== by 0x406BD3: base_residual_implicit
==25980== by 0x50597C2: MatFDColoringApply_BAIJ (baij.c:2815)
==25980== by 0x5022C69: MatFDColoringApply (fdmatrix.c:517)
==25980== by 0x57D2E9B: SNESDefaultComputeJacobianColor (snesj2.c:48)
==25980== by 0x57B7852: SNESComputeJacobian (snes.c:1357)
==25980== by 0x57FAEF8: SNESSolve_LS (ls.c:188)
==25980== by 0x57C43AA: SNESSolve (snes.c:2676)
==25980== by 0x58694E1: TSStep_Theta (theta.c:41)
==25980== by 0x58812D6: TSStep (ts.c:1776)
[4]PETSC ERROR: ==25980== by 0x4208A5: explicit_time
==25980== by 0x429E14: main (hoac.c:1250)
==25980== Address 0xe800000000b84400 is not stack'd, malloc'd or
(recently) free'd
==25980==
[7]PETSC ERROR: [0]PETSC ERROR: likely location of problem given in
stack below
[6]PETSC ERROR: [0]PETSC ERROR: --------------------- Stack Frames
[1]PETSC ERROR: [5]PETSC ERROR: [2]PETSC ERROR: [0]PETSC ERROR: Note:
The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:
INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[4]PETSC ERROR: [7]PETSC ERROR: Caught signal number 11 SEGV:
Segmentation Violation, probably memory access out of range
Caught signal number 11 SEGV: Segmentation Violation, probably memory
access out of range
[4]PETSC ERROR:
[7]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[4]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[7]PETSC
ERROR: [0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[4]PETSC
[7]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
X to find memory corruption errors
[6]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
[6]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[6]PETSC ERROR:
or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[6]PETSC
[0] MatMult line 2156
/home/kontzialis/petsc-3.2-p5/src/mat/interface/matrix.c
[0]PETSC ERROR: [0] base_residual_implicit line 27
"unknowndirectory/"../src/base_residual_implicit.c
[2]PETSC ERROR: [5]PETSC ERROR: [1]PETSC ERROR: Caught signal number 11
SEGV: Segmentation Violation, probably memory access out of range
access out of range
access out of range
[0]PETSC ERROR: [2]PETSC ERROR: [5]PETSC ERROR: [1]PETSC ERROR: Try
[0] MatFDColoringApply_BAIJ line 2768
/home/kontzialis/petsc-3.2-p5/src/mat/impls/baij/seq/baij.c
[1]PETSC ERROR: [5]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind[2]PETSC
ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrindor
see
ERROR: [0] MatFDColoringApply line 511
/home/kontzialis/petsc-3.2-p5/src/mat/matfd/fdmatrix.c
[1]PETSC ERROR: [5]PETSC ERROR: or try http://valgrind.org on GNU/linux
and Apple Mac OS X to find memory corruption errors
or try http://valgrind.org on GNU/linux and Apple Mac OS X to find
[2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
[4]PETSC ERROR: [0]PETSC ERROR: likely location of problem given in
stack below
[7]PETSC ERROR: likely location of problem given in stack below
[4]PETSC ERROR: [0] SNESDefaultComputeJacobianColor line 40
/home/kontzialis/petsc-3.2-p5/src/snes/interface/snesj2.c
--------------------- Stack Frames ------------------------------------
[7]PETSC ERROR: [0]PETSC ERROR: --------------------- Stack Frames
[0] SNES user Jacobian function line 0 unknownunknown
[0]PETSC ERROR: [0] SNESComputeJacobian line 1322
/home/kontzialis/petsc-3.2-p5/src/snes/interface/snes.c
[6]PETSC ERROR: likely location of problem given in stack below
[6]PETSC ERROR: --------------------- Stack Frames
[3]PETSC ERROR: [1]PETSC ERROR: [5]PETSC ERROR: likely location of
[2]PETSC ERROR: likely location of problem given in stack below
[1]PETSC ERROR: [5]PETSC ERROR: [2]PETSC ERROR: ---------------------
[0]PETSC ERROR: --------------------- Error Message
[4]PETSC ERROR: [7]PETSC ERROR: Note: The EXACT line numbers in the
Note: The EXACT line numbers in the stack are not available,
[4]PETSC ERROR: [7]PETSC ERROR: INSTEAD the line number of the
[4]PETSC ERROR: [7]PETSC ERROR: is given.
is given.
[6]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[6]PETSC ERROR: INSTEAD the line number of the start of the function
[6]PETSC ERROR: [4]PETSC ERROR: [7]PETSC ERROR: is given.
[0]PETSC ERROR: Signal received!
[6]PETSC ERROR: [0]PETSC ERROR: [2]PETSC ERROR: [7] MatMult line 2156
[1]PETSC ERROR: [5]PETSC ERROR: Note: The EXACT line numbers in the
[4] MatMult line 2156
[7]PETSC ERROR: [2]PETSC ERROR: [4]PETSC ERROR: INSTEAD the line
[1]PETSC ERROR: INSTEAD the line number of the start of the function
[5]PETSC ERROR: [7] base_residual_implicit line 27
[4] base_residual_implicit line 27
[7]PETSC ERROR: INSTEAD the line number of the start of the function
[2]PETSC ERROR: [1]PETSC ERROR: [4]PETSC ERROR: [7]
is given.
is given.
[5]PETSC ERROR: [4] MatFDColoringApply_BAIJ line 2768
[7]PETSC ERROR: [4]PETSC ERROR: [0]PETSC ERROR: is given.
[7] MatFDColoringApply line 511
Petsc Release Version 3.2.0, Patch 5, Sat Oct 29 13:45:54 CDT 2011
[4] MatFDColoringApply line 511
[7]PETSC ERROR: [4]PETSC ERROR: [7] SNESDefaultComputeJacobianColor line
40 /home/kontzialis/petsc-3.2-p5/src/snes/interface/snesj2.c
[6] MatMult line 2156
[4] SNESDefaultComputeJacobianColor line 40
[7]PETSC ERROR: [4]PETSC ERROR: [7] SNES user Jacobian function line 0
unknownunknown
[6]PETSC ERROR: [7]PETSC ERROR: [4] SNES user Jacobian function line 0
unknownunknown
[0]PETSC ERROR: [7] SNESComputeJacobian line 1322
[6] base_residual_implicit line 27
[4]PETSC ERROR: [6]PETSC ERROR: See docs/changes/index.html for recent
updates.
[4] SNESComputeJacobian line 1322
[2]PETSC ERROR: [1]PETSC ERROR: [6] MatFDColoringApply_BAIJ line 2768
[6]PETSC ERROR: [5]PETSC ERROR: [6] MatFDColoringApply line 511
[6]PETSC ERROR: [0]PETSC ERROR: [6] SNESDefaultComputeJacobianColor line
See docs/faq.html for hints about trouble shooting.
[6]PETSC ERROR: [6] SNES user Jacobian function line 0 unknownunknown
[6]PETSC ERROR: [0]PETSC ERROR: [6] SNESComputeJacobian line 1322
See docs/index.html for manual pages.
[0]PETSC ERROR: [1] MatMult line 2156
[5] MatMult line 2156
[1]PETSC ERROR: [5]PETSC ERROR: [1] base_residual_implicit line 27
[1]PETSC ERROR: [5] base_residual_implicit line 27
[5]PETSC ERROR: [1] MatFDColoringApply_BAIJ line 2768
[5] MatFDColoringApply_BAIJ line 2768
[1]PETSC ERROR: [0]PETSC ERROR: [5]PETSC ERROR: [1] MatFDColoringApply
line 511 /home/kontzialis/petsc-3.2-p5/src/mat/matfd/fdmatrix.c
[5] MatFDColoringApply line 511
[1]PETSC ERROR: [5]PETSC ERROR: ./hoac on a linux-gnu named PlusSodaL by
kontzialis Sat Nov 5 21:36:27 2011
[1] SNESDefaultComputeJacobianColor line 40
[5] SNESDefaultComputeJacobianColor line 40
[1]PETSC ERROR: [5]PETSC ERROR: [1] SNES user Jacobian function line 0
unknownunknown
[1]PETSC ERROR: [5] SNES user Jacobian function line 0 unknownunknown
[1] SNESComputeJacobian line 1322
[5]PETSC ERROR: [0]PETSC ERROR: [5] SNESComputeJacobian line 1322
Libraries linked from /home/kontzialis/petsc-3.2-p5/linux-gnu-c-debug/lib
[0]PETSC ERROR: Configure run at Sat Nov 5 20:58:12 2011
[0]PETSC ERROR: Configure options --with-debugging=1
---with-mpi-dir=/usr/lib64/mpich2/bin --with-shared-libraries
--with-shared-libraries --with-large-file-io=1 --with-precision=double
--with-blacs=1 --download-blacs=yes --download-f-blas-lapack=yes
--with-plapack=1 --download-plapack=yes --with-scalapack=1
--download-scalapack=yes --with-superlu=1 --download-superlu=yes
--with-superlu_dist=1 --download-superlu_dist=yes --with-ml=1
--download-ml=yes --with-umfpack=1 --download-umfpack=yes --with-mpi=1
--download-mpich=1 --with-sundials=1 --download-sundials=1
--with-parmetis=1 --download-parmetis=1 --with-hypre=1 --download-hypre=1
[3]PETSC ERROR: [0]PETSC ERROR: Caught signal number 11 SEGV:
[7]PETSC ERROR: [3]PETSC ERROR: --------------------- Error Message
[4]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[2] MatMult line 2156
[6]PETSC ERROR: --------------------- Error Message
[2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[2] base_residual_implicit line 27
[2]PETSC ERROR: [3]PETSC ERROR: [2] MatFDColoringApply_BAIJ line 2768
or see
ERROR: [3]PETSC ERROR: [2] MatFDColoringApply line 511
[2] SNESDefaultComputeJacobianColor line 40
[2]PETSC ERROR: [2] SNES user Jacobian function line 0 unknownunknown
[2]PETSC ERROR: [2] SNESComputeJacobian line 1322
[1]PETSC ERROR: [5]PETSC ERROR: --------------------- Error Message
--------------------- Error Message ------------------------------------
[7]PETSC ERROR: Signal received!
[4]PETSC ERROR: Signal received!
[7]PETSC ERROR:
[4]PETSC ERROR:
[7]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
[4]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
[7]PETSC ERROR: [6]PETSC ERROR: See docs/changes/index.html for recent
updates.
See docs/changes/index.html for recent updates.
[7]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[4]PETSC ERROR: [6]PETSC ERROR: [3]PETSC ERROR: See docs/faq.html for
[7]PETSC ERROR: See docs/index.html for manual pages.
[3]PETSC ERROR: [4]PETSC ERROR: See docs/index.html for manual pages.
[7]PETSC ERROR:
[4]PETSC ERROR:
[6]PETSC ERROR: See docs/changes/index.html for recent updates.
[6]PETSC ERROR: [7]PETSC ERROR: [4]PETSC ERROR: See docs/faq.html for
./hoac on a linux-gnu named PlusSodaL by kontzialis Sat Nov 5 21:36:27 2011
[6]PETSC ERROR: [7]PETSC ERROR: See docs/index.html for manual pages.
[4]PETSC ERROR: Libraries linked from
[6]PETSC ERROR:
[7]PETSC ERROR: [4]PETSC ERROR: Configure run at Sat Nov 5 20:58:12 2011
[1]PETSC ERROR: Configure run at Sat Nov 5 20:58:12 2011
[5]PETSC ERROR: Signal received!
Signal received!
[6]PETSC ERROR: [7]PETSC ERROR: [4]PETSC ERROR: ./hoac on a linux-gnu
[1]PETSC ERROR: [2]PETSC ERROR: Configure options --with-debugging=1
[5]PETSC ERROR:
[6]PETSC ERROR: Configure run at Sat Nov 5 20:58:12 2011
[7]PETSC ERROR: [5]PETSC ERROR: [1]PETSC ERROR: [4]PETSC ERROR: User
provided function() line 0 in unknown directory unknown file
User provided function() line 0 in unknown directory unknown file
[6]PETSC ERROR: Configure options --with-debugging=1
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[5]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[6]PETSC ERROR: [1]PETSC ERROR: [5]PETSC ERROR:
[6]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[1]PETSC ERROR: [5]PETSC ERROR: Libraries linked from
[5]PETSC ERROR: [1]PETSC ERROR: Configure run at Sat Nov 5 20:58:12 2011
[5]PETSC ERROR: [1]PETSC ERROR: Configure options --with-debugging=1
[1]PETSC ERROR: [5]PETSC ERROR: User provided function() line 0 in
[2]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
Signal received!
[2]PETSC ERROR:
[2]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
[2]PETSC ERROR: See docs/changes/index.html for recent updates.
[2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[3]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[2]PETSC ERROR: See docs/index.html for manual pages.
[3]PETSC ERROR: INSTEAD the line number of the start of the function
[2]PETSC ERROR:
[3]PETSC ERROR: is given.
[2]PETSC ERROR: ./hoac on a linux-gnu named PlusSodaL by kontzialis Sat
Nov 5 21:36:27 2011
[2]PETSC ERROR: Libraries linked from
[2]PETSC ERROR: [3]PETSC ERROR: Configure run at Sat Nov 5 20:58:12 2011
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[2]PETSC ERROR:
unknown file
[3] MatMult line 2156
[3]PETSC ERROR: [3] base_residual_implicit line 27
[3]PETSC ERROR: [3] MatFDColoringApply_BAIJ line 2768
[3]PETSC ERROR: [3] MatFDColoringApply line 511
[3]PETSC ERROR: [3] SNESDefaultComputeJacobianColor line 40
[3]PETSC ERROR: [3] SNES user Jacobian function line 0 unknownunknown
[3]PETSC ERROR: [3] SNESComputeJacobian line 1322
[cli_0]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 7
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 4
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 6
[cli_7]: [cli_4]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 5
aborting job:
[cli_6]: aborting job:
[cli_1]: [cli_5]: aborting job:
aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 2
[3]PETSC ERROR: Signal received!
[3]PETSC ERROR:
[3]PETSC ERROR: Petsc Release Version 3.2.0, Patch 5, Sat Oct 29
13:45:54 CDT 2011
[3]PETSC ERROR: See docs/changes/index.html for recent updates.
[3]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[3]PETSC ERROR: See docs/index.html for manual pages.
[3]PETSC ERROR:
[3]PETSC ERROR: ./hoac on a linux-gnu named PlusSodaL by kontzialis Sat
Nov 5 21:36:27 2011
[3]PETSC ERROR: [cli_2]: Libraries linked from
[3]PETSC ERROR: aborting job:
[3]PETSC ERROR: Configure options --with-debugging=1
[3]PETSC ERROR:
[3]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 3
[cli_3]: aborting job:
==25984==
==25984== HEAP SUMMARY:
==25984== in use at exit: 2,998,242 bytes in 3,058 blocks
==25984== total heap usage: 6,616 allocs, 3,558 frees, 25,981,044
bytes allocated
==25984==
==25983==
==25983== HEAP SUMMARY:
==25983== in use at exit: 3,495,890 bytes in 3,233 blocks
==25983== total heap usage: 6,903 allocs, 3,670 frees, 25,400,971
bytes allocated
==25983==
==25977==
==25981==
==25977== HEAP SUMMARY:
==25977== in use at exit: 3,068,055 bytes in 3,075 blocks
==25977== total heap usage: 6,625 allocs, 3,550 frees, 22,077,530
bytes allocated
==25977==
==25981== HEAP SUMMARY:
==25981== in use at exit: 3,236,727 bytes in 3,119 blocks
==25981== total heap usage: 6,700 allocs, 3,581 frees, 23,513,895
bytes allocated
==25981==
==25978==
==25982==
==25982== HEAP SUMMARY:
==25982== in use at exit: 3,291,403 bytes in 3,135 blocks
==25982== total heap usage: 6,712 allocs, 3,577 frees, 24,919,538
bytes allocated
==25982==
==25978== HEAP SUMMARY:
==25978== in use at exit: 2,948,439 bytes in 3,043 blocks
==25978== total heap usage: 6,477 allocs, 3,434 frees, 18,814,766
bytes allocated
==25978==
==25979==
==25979== HEAP SUMMARY:
==25979== in use at exit: 2,921,710 bytes in 3,093 blocks
==25979== total heap usage: 6,538 allocs, 3,445 frees, 14,632,326
bytes allocated
==25979==
==25980==
==25980== HEAP SUMMARY:
==25980== in use at exit: 2,940,474 bytes in 3,056 blocks
==25980== total heap usage: 6,597 allocs, 3,541 frees, 24,476,005
bytes allocated
==25980==
==25984== LEAK SUMMARY:
==25984== definitely lost: 584 bytes in 16 blocks
==25984== indirectly lost: 128 bytes in 8 blocks
==25984== possibly lost: 0 bytes in 0 blocks
==25984== still reachable: 2,997,530 bytes in 3,034 blocks
==25984== suppressed: 0 bytes in 0 blocks
==25984== Rerun with --leak-check=full to see details of leaked memory
==25984==
==25984== For counts of detected and suppressed errors, rerun with: -v
==25984== Use --track-origins=yes to see where uninitialised values come
from
==25984== ERROR SUMMARY: 3 errors from 3 contexts (suppressed: 6 from 6)
==25977== LEAK SUMMARY:
==25977== definitely lost: 584 bytes in 16 blocks
==25977== indirectly lost: 128 bytes in 8 blocks
==25977== possibly lost: 0 bytes in 0 blocks
==25977== still reachable: 3,067,343 bytes in 3,051 blocks
==25977== suppressed: 0 bytes in 0 blocks
==25977== Rerun with --leak-check=full to see details of leaked memory
==25977==
==25977== For counts of detected and suppressed errors, rerun with: -v
==25977== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 6 from 6)
==25981== LEAK SUMMARY:
==25981== definitely lost: 584 bytes in 16 blocks
==25981== indirectly lost: 128 bytes in 8 blocks
==25981== possibly lost: 0 bytes in 0 blocks
==25981== still reachable: 3,236,015 bytes in 3,095 blocks
==25981== suppressed: 0 bytes in 0 blocks
==25981== Rerun with --leak-check=full to see details of leaked memory
==25981==
==25981== For counts of detected and suppressed errors, rerun with: -v
==25981== Use --track-origins=yes to see where uninitialised values come
from
==25981== ERROR SUMMARY: 3 errors from 3 contexts (suppressed: 6 from 6)
==25983== LEAK SUMMARY:
==25983== definitely lost: 584 bytes in 16 blocks
==25983== indirectly lost: 128 bytes in 8 blocks
==25983== possibly lost: 0 bytes in 0 blocks
==25983== still reachable: 3,495,178 bytes in 3,209 blocks
==25983== suppressed: 0 bytes in 0 blocks
==25983== Rerun with --leak-check=full to see details of leaked memory
==25983==
==25983== For counts of detected and suppressed errors, rerun with: -v
==25983== Use --track-origins=yes to see where uninitialised values come
from
==25983== ERROR SUMMARY: 3 errors from 3 contexts (suppressed: 6 from 6)
==25978== LEAK SUMMARY:
==25978== definitely lost: 584 bytes in 16 blocks
==25978== indirectly lost: 128 bytes in 8 blocks
==25978== possibly lost: 0 bytes in 0 blocks
==25978== still reachable: 2,947,727 bytes in 3,019 blocks
==25978== suppressed: 0 bytes in 0 blocks
==25978== Rerun with --leak-check=full to see details of leaked memory
==25978==
==25978== For counts of detected and suppressed errors, rerun with: -v
==25978== Use --track-origins=yes to see where uninitialised values come
from
==25978== ERROR SUMMARY: 3 errors from 3 contexts (suppressed: 6 from 6)
My base_residual_implicit function is the following:
/* Function name:
base_residual_implicit.c */
/* Engineer:
C.Kontzialis */
/* E-mail:
ckontzialis at lycos.com */
/* Function
description: */
/* Function base_residual_implicit.c computes the residual at every
element for the NS*/
equations.
/* Data structure for hoac */
#include "hoac.h"
PetscErrorCode base_residual_implicit(TS ts, /* Time stepper context [in] */
PetscReal t, /* Time t [in]*/
Vec sv, /* Global vector [in]*/
Vec svt, /* Global vector [in]*/
Vec gres, /* Global vector [out]*/
void *ctx /* HoAc Context [in]*/
PetscErrorCode ierr;
SYS sys = *((SYS *) ctx);
PetscFunctionBegin;
ierr = MatMult(sys.M, svt, sys.gsvk);
CHKERRQ(ierr);
ierr = residual(sv, gres, ctx);
CHKERRQ(ierr);
ierr = VecAXPY(gres, 1.0, sys.gsvk);
CHKERRQ(ierr);
PetscFunctionReturn(0);
} /* base_residual_implicit.c */
But, even though there is a computation of the residual and I get a result:
an error occurs. Why? What should I do?
Thank you very much!!!
Kostas
