[petsc-users] fixed point interations
Sat Nov 5 09:06:02 CDT 2011
On Sat, Nov 5, 2011 at 1:23 PM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> I am a newcomer to Petsc non-linear capabilities, so far implementing
> such things myself, only delegating linear solves to Petsc.
> I want to start small by porting a very simple code using fixed point
> iterations as follows: A(x)x = b(x) is approximated as A(x0)x = b(x0),
> then solved by KSP for x, then x0 is updated to x, then repeat until
> convergence.
> In the documentation chapter 5 I see all sorts of sophisticated Newton
> type methods, requiring computation of the Jacobian. Is the above
> defined simple method still accessible somehow in Petsc or such
> triviality can only be done by hand? Which one from the existing
> nonlinear solvers would be a closest match both in simplicity and
> robustness (even if slow performance)?
You want -snes_type nrichardson. All you need is to define the residual.
   Matt
> Regards,
> Dominik
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111105/6b135aa7/attachment.htm>
