[petsc-users] no profile printed by "PetscLogPrintSummary"
Debao Shao
Debao.Shao at brion.com
Tue Nov 1 22:00:31 CDT 2011
Hi, Matt:
My petsc version is 3.1-p8, I can't find "PetscLogView", is it similar behavior as "PetscLogDump"?
Debao
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Matthew Knepley
Sent: Wednesday, November 02, 2011 10:51 AM
To: PETSc users list
Subject: Re: [petsc-users] no profile printed by "PetscLogPrintSummary"
On Wed, Nov 2, 2011 at 2:30 AM, Debao Shao <Debao.Shao at brion.com<mailto:Debao.Shao at brion.com>> wrote:
Hi, Matt:
1, I tried both "PetscLogAllBegin()" & "PetscLogBegin()", but both of them don't print log summary.
2, I disabled MPI(--with-mpi=0), will MPI_COMM_SELF have difference to PETSC_COMM_WORLD?
Works for me:
#include <petscsys.h>
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc, char **argv)
PetscErrorCode ierr;
ierr = PetscInitialize(&argc, &argv, PETSC_NULL, PETSC_NULL);CHKERRQ(ierr);
ierr = PetscLogBegin();CHKERRQ(ierr);
ierr = PetscLogView(PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
ierr = PetscFinalize();
return 0;
which gives
Executing: /PETSc3/petsc/petsc-dev-pylith/arch-sieve-fdatatypes-debug/bin/mpiexec -n 1 /PETSc3/petsc/petsc-dev-pylith/arch-sieve-fdatatypes-debug/lib/tester-obj/tester
sh: ************************************************************************************************************************
*** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
/PETSc3/petsc/petsc-dev-pylith/arch-sieve-fdatatypes-debug/lib/tester-obj/tester on a arch-siev named MATTHEW-KNEPLEYs-MacBook-Air-2.local with 1 processor, by knepley Tue Nov 1 21:50:08 2011
Using Petsc Development HG revision: 56a54b25d97df6f01a55abded4076de34409738b HG Date: Tue Nov 01 17:11:12 2011 -0500
Max Max/Min Avg Total
Time (sec): 5.988e-03 1.00000 5.988e-03
Objects: 1.000e+00 1.00000 1.000e+00
Flops: 0.000e+00 0.00000 0.000e+00 0.000e+00
Flops/sec: 0.000e+00 0.00000 0.000e+00 0.000e+00
Memory: 8.486e+04 1.00000 8.486e+04
MPI Messages: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Message Lengths: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Reductions: 1.000e+00 1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flops
and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts %Total Avg %Total counts %Total
0: Main Stage: 5.9600e-03 99.5% 0.0000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flops: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %f - percent flops in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
# WARNING!!! #
# This code was compiled with a debugging option, #
# To get timing results run ./configure #
# using --with-debugging=no, the performance will #
# be generally two or three times faster. #
Event Count Time (sec) Flops --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %f %M %L %R %T %f %M %L %R Mflop/s
--- Event Stage 0: Main Stage
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Viewer 1 0 0 0
Average time to get PetscTime(): 4.05312e-07
#No PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8
Configure run at: Tue Nov 1 18:04:19 2011
Configure options: --PETSC_ARCH=arch-sieve-fdatatypes-debug --download-boost --download-chaco --download-fiat --download-hdf5 --download-ml --download-mpich --download-netcdf --download-parmetis --download-scientificpython --download-tetgen --download-triangle --with-clanguage=C++ --with-dynamic-loading --with-exodusii-dir=/PETSc3/petsc/exodusii-4.98 --with-fc="gfortran -cpp" --with-fortran-datatypes --with-shared-libraries --with-sieve --with-sieve-memory-logging
Libraries compiled on Tue Nov 1 18:04:19 2011 on MATTHEW-KNEPLEYs-MacBook-Air-2.local
Machine characteristics: Darwin-10.8.0-i386-64bit
Using PETSc directory: /PETSc3/petsc/petsc-dev-pylith
Using PETSc arch: arch-sieve-fdatatypes-debug
Using C compiler: /PETSc3/petsc/petsc-dev-pylith/arch-sieve-fdatatypes-debug/bin/mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -PIC ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /PETSc3/petsc/petsc-dev-pylith/arch-sieve-fdatatypes-debug/bin/mpif90 -fPIC -Wall -Wno-unused-variable -Wno-unused-dummy-argument -g ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/PETSc3/petsc/petsc-dev-pylith/arch-sieve-fdatatypes-debug/include -I/PETSc3/petsc/petsc-dev-pylith/include -I/PETSc3/petsc/petsc-dev-pylith/include -I/PETSc3/petsc/petsc-dev-pylith/arch-sieve-fdatatypes-debug/include -I/PETSc3/petsc/petsc-dev-pylith/include/sieve -I/PETSc3/petsc/exodusii-4.98/include -I/PETSc3/petsc/exodusii-4.98/cbind/include -I/PETSc3/petsc/exodusii-4.98/forbind/include
Using C linker: /PETSc3/petsc/petsc-dev-pylith/arch-sieve-fdatatypes-debug/bin/mpicxx
Using Fortran linker: /PETSc3/petsc/petsc-dev-pylith/arch-sieve-fdatatypes-debug/bin/mpif90
Using libraries: -L/PETSc3/petsc/petsc-dev-pylith/arch-sieve-fdatatypes-debug/lib -L/PETSc3/petsc/petsc-dev-pylith/arch-sieve-fdatatypes-debug/lib -lpetsc -L/PETSc3/petsc/petsc-dev-pylith/arch-sieve-fdatatypes-debug/lib -ltriangle -L/usr/X11R6/lib -lX11 -lchaco -lml -lparmetis -lmetis -lpthread -ltet -llapack -lblas -L/PETSc3/petsc/exodusii-4.98/. -lexoIIv2for -lexodus -lnetcdf_c++ -lnetcdf -lhdf5_fortran -lhdf5 -lz -L/usr/lib/gcc/i686-apple-darwin10/4.2.1/x86_64 -L/usr/lib/i686-apple-darwin10/4.2.1 -L/usr/lib/gcc/i686-apple-darwin10/4.2.1 -ldl -lpmpich -lmpich -lopa -lmpl -lpthread -lSystem -lmpichf90 -lgfortran -L/usr/local/lib/gcc/x86_64-apple-darwin10.4.0/4.6.0 -L/usr/local/lib -lgfortran -lgcc_ext.10.5 -lmpichcxx -lstdc++ -lmpichcxx -lstdc++ -ldl -lpmpich -lmpich -lopa -lmpl -lpthread -lSystem -ldl
Matt
Debao
From: petsc-users-bounces at mcs.anl.gov<mailto:petsc-users-bounces at mcs.anl.gov> [mailto:petsc-users-bounces at mcs.anl.gov<mailto:petsc-users-bounces at mcs.anl.gov>] On Behalf Of Matthew Knepley
Sent: Tuesday, November 01, 2011 7:03 PM
On Tue, Nov 1, 2011 at 9:31 AM, Debao Shao <Debao.Shao at brion.com<mailto:Debao.Shao at brion.com>> wrote:
DA,
I intend to use "PetscLogPrintSummary" to dump log summary, but don't get it.
The usage is:
PetscInitialize(0, 0, 0, 0);
PetscLogAllBegin();
PetscLogPrintSummary(MPI_COMM_SELF, PETSC_NULL);
PetscFinalize();
You only need PetscLogBegin(), and you should use PETSC_COMM_WORLD.
Matt
My libpetsc.a is built by
1, ./config/configure.py --with-mpi=0 --with-debugging=1 -with-log=1 -with-info=1 --with-x=0;
2, make all
Debao
-- The information contained in this communication and any attachments is confidential and may be privileged, and is for the sole use of the intended recipient(s). Any unauthorized review, use, disclosure or distribution is prohibited. Unless explicitly stated otherwise in the body of this communication or the attachment thereto (if any), the information is provided on an AS-IS basis without any express or implied warranties or liabilities. To the extent you are relying on this information, you are doing so at your own risk. If you are not the intended recipient, please notify the sender immediately by replying to this message and destroy all copies of this message and any attachments. ASML is neither liable for the proper and complete transmission of the information contained in this communication, nor for any delay in its receipt.
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111101/6a61eb6f/attachment-0001.htm>
