[petsc-users] DMDA and vector PDE
Matthew Knepley
knepley at gmail.com
Tue Nov 1 14:58:54 CDT 2011
On Tue, Nov 1, 2011 at 4:13 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Nov 1, 2011 at 10:06, Alexander Grayver <agrayver at gfz-potsdam.de>wrote:
>> Thanks Jed, looks easy. I've read about this parameter in documentation,
>> but it wasn't obvious how to use it.
>> May be it's worth to mention it shortly in "2.4.4 Accessing the Vector
>> Entries for DMDA Vectors" or somewhere else.
> I'll add a note. The most common approach is to declare a struct
> typedef struct {
> PetscScalar u,v,omega,temp;
> } Field;
> and then access as x[j][i].omega, etc. An example:
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/src/snes/examples/tutorials/ex50.c.html
Or you can use
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/DM/DMDAVecGetArrayDOF.html
and access it as x[j][i][0-3].
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111101/301528de/attachment.htm>
