[petsc-users] V-cycle multigrid with matrix shells
Jed Brown jed at 59A2.org
Tue May 17 13:56:52 CDT 2011
On Tue, May 17, 2011 at 20:32, Sylvain Barbot <sylbar.vainbot at gmail.com>wrote:
> You're right, I should experiment more with assembled matrices before
> choosing a solver/preconditioner. Could you be more specific about the
> command line options that I could test. I have a version of the code
> with assembled sparse matrices (default format). I tried running with
> the option -pc_type mg and got the following error:
You need to set grid information or interpolation operators for this to
work. If you have a grid hierarchy, you can set it by following that chapter
of the user's manual (which I think you were trying to do with matrix-free
operators everywhere). If you use a structured grid, DMMG is quite
convenient.
(petsc-dev does not seg-fault on the configuration you gave because the data
structure has been improved)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110517/36553911/attachment.htm>
