[petsc-users] Parallel direct solver
Ormiston, Scott J.
SJ_Ormiston at UManitoba.ca
Thu Mar 31 06:57:27 CDT 2011
I need to be able to run a parallel version of a direct solver.
Is there a parallel direct solver in PETSc? My understanding is that the
direct solver in PETSc is only sequential.
If there is no parallel direct solver in PETSc, what should I use? I
have seen some people recommend SuperLU. This seems to be a totally
separate package from PETSc with its own syntax and setup. Therefore, I
must start from scratch with the SuperLU setup and I cannot take
advantage of the parallel matrix setup that I have already done to solve
my problem with a ksp solver with PETSc. Is this my only option?
Scott Ormiston
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110331/8cfba930/attachment.vcf>
