[petsc-users] Petsc and Matlab R2010b
domenico.borzacchiello at univ-st-etienne.fr domenico.borzacchiello at univ-st-etienne.fr
Wed Mar 30 08:04:44 CDT 2011
I'm trying to build Petsc (current release) with Matlab R2010b with the
following command line
./config/configure.py --with-cc=icc --with-fc=ifort
--download-f-blas-lapack=1 --download-mpich=1
--with-matlab-dir=/opt/MATLAB/R2010b --with-matlab-engine
The configuration stage is successfully completed. then If I build the
libraries I get the following warning messages:
BEGINNING TO COMPILE MATLAB INTERFACE
sread.c(35): warning #188: enumerated type mixed with another type
      ierr = PetscBinaryRead(fd,mxGetPr(plhs[0]),cnt,dt);if (ierr)
PETSC_MEX_ERROR("Unable to receive double items.");
sread.c(38): warning #188: enumerated type mixed with another type
PETSC_MEX_ERROR("Unable to receive int items.");
sread.c(41): warning #188: enumerated type mixed with another type
      ierr = PetscBinaryRead(fd,tmp,cnt,dt);if (ierr)
PETSC_MEX_ERROR("Unable to receive char items.");
ld: sread.o: relocation R_X86_64_32 against `.rodata' can not be used when
making a shared object; recompile with -fPIC
sread.o: could not read symbols: Bad value
    mex: link of ' "sread.mexa64"' failed.
make[10]: [sread] Errore 1 (ignorato)
/bin/mv: impossibile eseguire stat di "sread.mex*": File o directory non
esistente
ld: sopen.o: relocation R_X86_64_32 against `.rodata' can not be used when
sopen.o: could not read symbols: Bad value
    mex: link of ' "sopen.mexa64"' failed.
make[10]: [sopen] Errore 1 (ignorato)
/bin/mv: impossibile eseguire stat di "sopen.mex*": File o directory non
esistente
ld: sclose.o: relocation R_X86_64_32 against `.rodata' can not be used
when making a shared object; recompile with -fPIC
sclose.o: could not read symbols: Bad value
    mex: link of ' "sclose.mexa64"' failed.
make[10]: [sclose] Errore 1 (ignorato)
/bin/mv: impossibile eseguire stat di "sclose.mex*": File o directory non
esistente
swrite.c(32): warning #188: enumerated type mixed with another type
      ierr = PetscBinaryWrite(fd,mxGetPr(prhs[1]),cnt,dt,PETSC_FALSE);if
(ierr) PETSC_MEX_ERROR("Unable to send double items.");
swrite.c(37): warning #188: enumerated type mixed with another type
      ierr = PetscBinaryWrite(fd,tmp,cnt,dt,PETSC_FALSE);if (ierr)
PETSC_MEX_ERROR("Unable to send int items.");
swrite.c(42): warning #188: enumerated type mixed with another type
PETSC_MEX_ERROR("Unable to send char items.");
ld: swrite.o: relocation R_X86_64_32 against `.rodata' can not be used
swrite.o: could not read symbols: Bad value
    mex: link of ' "swrite.mexa64"' failed.
Then if I try to run the tests i get the error:
ld: cannot find -licudata
ld: cannot find -licui18n
ld: cannot find -licuuc
ld: cannot find -lustdio
What am I doing wrong? It worked perfectly without the matlab engine?
Thank you in advance,
Domenico
