[petsc-users] Howto use pARMS
Jed Brown
jed at 59A2.org
Wed Mar 23 09:49:11 CDT 2011
2011/3/23 Gong Ding <gdiso at ustc.edu>
> ilu is powerful preconditioner, especially for my problem.
> However, petsc only has a simple serial version.
> Hypre parallel ilu does not scalar well.
> I hole pARMS works fine.
Note that pARMS is not doing parallel ILU. To see the options, run with
-pc_type parms -help | grep parms
This one is especially relevant:
-pc_parms_global <RAS> (choose one of) RAS SCHUR BJ (PCPARMSSetGlobal)
note that SCHUR is nonlinear by default so you should use -ksp_type fgmres
> BTW, pastix announced it support parallel ilu (kass module),
> is it possible to call pastix kass in petsc?
That is not implemented, but someone could update the module.
Note that -pc_type hypre -pc_hypre_type euclid is also a parallel ILU.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110323/bba9830f/attachment.htm>
