[petsc-users] custom sparse matrix
Mon Mar 21 08:14:03 CDT 2011
On Mar 21, 2011, at 6:43 AM, Alejandro Marcos Aragón wrote:
> Hi everyone,
> I'm new to the list and to PETSc. I was wondering if this is possible: in my code I have my own sparse matrix data structure, so instead of creating a sparse matrix from PETSc and copying all the elements, I was wondering if there is a way to specify the storage of the elements. My custom data structure is a three-array compressed row format (or compressed column storage).
   If it truly is CSR you an use MatCreateSeqAIJWithArrays() or MatCreateMPIAIJWithArrays(). Otherwise you can use MatCreateShell() and provide your own function operations for MatMult() and whatever you will need.
   Generally keeping your own sparse matrix data structure is overrated, yes you may save a little time and a little memory but then you use all the flexibility and power of PETSc sparse matrices; why bother with PETSc in that case.
   Barry
> Thank you,
> Alejandro M. Aragón, Ph.D.
