[petsc-users] MatAYPX for dense and sparse matrices
Alexander Grayver
agrayver at gfz-potsdam.de
Mon Mar 21 07:49:55 CDT 2011
On 21.03.2011 12:45, Matthew Knepley wrote:
> On Mon, Mar 21, 2011 at 6:40 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
> On 21.03.2011 12 <tel:21.03.2011%2012>:37, Jed Brown wrote:
>> On Mon, Mar 21, 2011 at 12:31, Alexander Grayver
>> Would I have to rebuild PETSc from scratch to make this
>> wrapper working?
>> You would put it in your project and link it with your Fortran code.
>>> Alternatively, the code for this is really simple, just
>>> iterate through the rows of L and insert them into J.
>> Do you mean using
>> MatGetOwnershipRange+MatGetSubMatrices+MatGetRow?
>> Just translate the following (taken from MatAXPY_Basic) to Fortran:
>> ierr = MatGetSize(X,&m,&n);CHKERRQ(ierr);
>> ierr = MatGetOwnershipRange(X,&start,&end);CHKERRQ(ierr);
>> for (i = start; i < end; i++) {
>> ierr = MatGetRow(X,i,&ncols,&row,&vals);CHKERRQ(ierr);
>> ierr =
>> MatSetValues(Y,1,&i,ncols,row,vals,ADD_VALUES);CHKERRQ(ierr);
>> ierr = MatRestoreRow(X,i,&ncols,&row,&vals);CHKERRQ(ierr);
>> ierr = MatAssemblyBegin(Y,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> ierr = MatAssemblyEnd(Y,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> Thanks Jed, it looks simple enough for me (PETSc is great).
> One more question. I get matrix J out of MatMatMult operation and
> then I have to add L matrix up, wouldn't there be a conflict using
> MatAssemblyBegin/MatAssemblyEnd again? Generally, is it allowed to
> set new values into the matrix after
> MatAssemblyBegin/MatAssemblyEnd already has been done once?
> No, you can use them. However, if you are adding to existing values on
> your process, nothing happens.
> Matt
> Thanks a lot.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Matt
Jed,
Thanks a lot!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110321/05ab45b2/attachment.htm>
