[petsc-users] MatAYPX for dense and sparse matrices
Aron Ahmadia
aron.ahmadia at kaust.edu.sa
Mon Mar 21 06:23:11 CDT 2011
Alex,
If you are adding a sparse matrix to a dense one, you are better off just
iterating through the values of your sparse matrix and adding them to your
dense matrix.
As far as I know, there are no routines in PETSc that will do this
automatically for you (and this sort of thing is really not PETSc's
strength).
A
On Mon, Mar 21, 2011 at 2:14 PM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
> Hello!
> I have two matrices L and J. L is the sparse with 2 nonzeros per row
> maximum (quite often there are no values in a row at all) and J is the dense
> matrix. I need to add matrix L to matrix J so that:
> J = J + L
> I try to use:
> call MatAYPX(J,one,L,SUBSET_NONZERO_PATTERN,ierr)
> Because it seems most obvious and efficient way.
> and program crashes with this callstack:
> unknown :: BLASaxpy_
> dense.c :: MatAXPY_SeqDense
> axpy.c :: MatAXPY
> axpy.c :: MatAYPX
> axpyf.c :: MATAYPX
> MODELING_MOD::MODELING
> I figured out the only one working combination:
> call MatAXPY(LT,one,JT,DIFFERENT_NONZERO_PATTERN,ierr)
> But this is very slow and inefficient.
> What actually could be done in such a situation?
> Thanks in advance.
> Regards,
> Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110321/6ee8c477/attachment.htm>
