[petsc-users] -snes_type test
Gianluca Meneghello
gianmail at gmail.com
Fri Mar 18 08:16:31 CDT 2011
Sorry, one more thing... is there a way to see/save/load into matlab
the difference between the computed jacobian and the fd one, apart
from output to screen?
thanks
gianlu
On 18 March 2011 14:03, Gianluca Meneghello <gianmail at gmail.com> wrote:
> Yes, my starting state is 0, not such a good guess...
> what do you mean by constant +1 and constant -1? Is it the
> starting/user-defined state vector +1 and -1?
> My problem should not be ill posed --- it's the Jacobian of the Navier
> Stokes operator, with good boundary conditions, at least theoretically
> --- but still I tried what you suggested. Here is the output
> using -mat_fd_type_ds -snes_type test:
> Testing hand-coded Jacobian, if the ratio is
> O(1.e-8), the hand-coded Jacobian is probably correct.
> Run with -snes_test_display to show difference
> of hand-coded and finite difference Jacobian.
> Norm of matrix ratio 9.17279e-09 difference 2.58883e-06
> Norm of matrix ratio 8.79304e-08 difference 2.59233e-05
> Norm of matrix ratio 8.87045e-08 difference 2.58875e-05
> while using -ksp_rtol 1e-12 -pc_type lu -snes_monitor
> 0 SNES Function norm 2.981436587230e+00
> 1 SNES Function norm 1.487397936082e+00
> 2 SNES Function norm 3.490136703474e-01
> 3 SNES Function norm 1.303397000344e-01
> 4 SNES Function norm 3.181190030949e-02
> 5 SNES Function norm 5.280858553562e-03
> 6 SNES Function norm 3.168168082141e-04
> 7 SNES Function norm 1.217775965490e-06
> 8 SNES Function norm 1.559322624068e-11
> do I have to deduce that it's ill posed?
> thanks
> gianluca
> On 18 March 2011 12:54, Jed Brown <jed at 59a2.org> wrote:
>> On Fri, Mar 18, 2011 at 12:41, Gianluca Meneghello <gianmail at gmail.com>
>> wrote:
>>> One more thing: what does the three lines stand for then? I was
>>> thinking it was three Newton steps, but I understand it's not...
>> It is your Jacobian evaluated at user-defined state, constant -1.0, and
>> constant 1.0. I added this to the output for petsc-dev:
>> $ ./ex5 -snes_type test
>> Norm of matrix ratio 2.77166e-08 difference 2.17871e-07 (user-defined state)
>> Norm of matrix ratio 1.34123e-08 difference 1.23213e-07 (constant state
>> -1.0)
>> Norm of matrix ratio 1.31875e-07 difference 9.05494e-07 (constant state 1.0)
>> [0]PETSC ERROR: SNESSolve() line 2360 in
>> /home/jed/petsc/src/snes/interface/snes.c
>> [0]PETSC ERROR: main() line 220 in src/snes/examples/tutorials/ex5.c
>>> The output I sent was actually the output of one of your examples. The
>>> one from my own code is
>>> Norm of matrix ratio 9.17257e-08 difference 2.58876e-05
>> Is your starting state zero?
>>> Norm of matrix ratio 1.45865e-06 difference 0.000430034
>>> Norm of matrix ratio 1.47148e-06 difference 0.000429436
>> If your problem is ill-conditioned, this might come from differencing error.
>> Try with -mat_fd_type ds to use a slightly more robust scheme. You can also
>> run with -ksp_rtol 1e-12 -pc_type lu -snes_monitor and check if you see
>> quadratic convergence.
> "[Je pense que] l'homme est un monde qui vaut des fois les mondes et
> que les plus ardentes ambitions sont celles qui ont eu l'orgueil de
> l'Anonymat" -- Non omnibus, sed mihi et tibi
> Amedeo Modigliani
Amedeo Modigliani
