[petsc-users] Which preconditioners are scalable?
Sebastian Steiger
steiger at purdue.edu
Fri Mar 11 09:52:02 CST 2011
Hello PETSc developers
I'm doing some scaling benchmarks and I found that the parallel asm
preconditioner, my favorite preconditioner, has a limit in the number of
cores it can handle.
I am doing a numerical experiment where I scale up the size of my matrix
by roughly the same factor as the number of CPUs employed. When I look
at which function used how much memory using PETSc's routine
PetscMallocDumpLog, I see the following:
Function name N=300 N=600 increase
MatGetSubMatrices_MPIAIJ_Local 75'912'016 134'516'928 1.77
MatIncreaseOverlap_MPIAIJ_Once 168'288'288 346'870'832 2.06
MatIncreaseOverlap_MPIAIJ_Receive 2'918'960 5'658'160 1.94
The matrix sizes are 6'899'904 and 14'224'896, respectively. Above
N~5000 CPUs I am running out of memory.
Here's my question now: Is the asm preconditioner limited from the
algorithm point of view, or is it the implementation? I thought that
'only' the local matrices, plus some constant overlap with neighbors,
are solved, so that memory consumption should stay constant when I scale
up with a constant number of rows per process.
Best
Sebastian
