[petsc-users] KSP Residual for GMRES
Travis C. Fisher travis.fisher at nasa.gov
Wed Mar 9 10:53:58 CST 2011
I am running a Navier Stokes Solver that uses implicit Runge Kutta for
timestepping. I am using SNES to perform preconditioned JFNK. As a
sanity check, I am running in serial and using the FD generated Jacobian
at the beginning of a time step as the preconditioner matrix for the
linear solves, and superlu_dist as the preconditioner. This means that
the linear solve (GMRES) for the first Newton iteration of the first
stage should converge almost exactly. I do not observe this for large
time steps. While it does converge to the Eisenstat-Walker convergence
criterion, the KSP residual norm is not small. It only decreases four
orders of magnitude. My question is whether or not this is the
preconditioned residual? The solver spits out the same residual whether
or not I use left or right preconditioning. I should also mention that
in this case I have turned off all viscous cross terms and the problem
is essentially 1-D, so I have taken as much care as possible to ensure
that the FD jacobian is a proper representation of the system.
Additionally, I observe the same problem in the inviscid case with both
the FD jacobian and the exact jacobian that I have computed. I
appreciate any insight you can give me into this observation.
Travis Fisher
