[petsc-users] Condition number of a matrix
Tim Kroeger
tim.kroeger at cevis.uni-bremen.de
Tue Mar 8 07:10:50 CST 2011
On Tue, 8 Mar 2011, Jose E. Roman wrote:
> On 08/03/2011, Tim Kroeger wrote:
>> Is there some possibility in PETSc to compute (an approximation to)
>> the condition number of a matrix? The matrix is a rank-1
>> modification of a sparse matrix, and I am anyway using SuperLU_Dist
>> to compute a factorization of the matrix. The matrix is about
>> 70000 times 70000.
> You can compute the condition number as the ratio of the largest to
> the smallest singular value (or eigenvalue in case of symmetric
> matrices). With SLEPc you can compute either eigenvalues or singular
> values. Here is an example that computes the condition number:
> http://www.grycap.upv.es/slepc/documentation/current/src/examples/ex8.c.html
> PETSc itself provides some tools for approximating the extreme
> singular values of the preconditioned operator, see
> KSPComputeExtremeSingularValues.
Thank you for your help. Following the notes in the manual page for
KSPComputeExtremeSingularValues(), I tried -ksp_monitor_singular_value
as a first approach, but this causes my application to crash. I
should say that the matrix is a ShellMat, consisting of a sum of a
rank-1 matrix and a sparse matrix, where the sparse matrix has been
factored by SuperLU_Dist. (I think this was somehow misleading in my
previous email.) I suspect that my ShellMat misses some operation
that is required, but I have no idea which that is. Could you please
let me know which operations are required for a ShellMat to enable
-ksp_monitor_singular_value?
Best Regards,
Tim
Dr. Tim Kroeger
CeVis -- Center of Complex Systems and Visualization
University of Bremen tim.kroeger at cevis.uni-bremen.de
Universitaetsallee 29 tim.kroeger at mevis.fraunhofer.de
D-28359 Bremen Phone +49-421-218-59246
Germany Fax +49-421-218-59277
