[petsc-users] how to use MatSetValues?
Gianluca Meneghello
gianmail at gmail.com
Tue Mar 8 03:23:34 CST 2011
You should do a loop over the values
for (int i = 0; i < 5; i++)
MatSetValues(xx,1,row[i],1,col[i],val[i],INSERT_VALUES);
On 8 March 2011 10:16, Tomasz Jankowski <tomjan at jay.au.poznan.pl> wrote:
>> I think m and n are the number of rows and columns you are inserting
>> in the matrix. If you insert one value at a time, that would be
>> MatSetValues(xx,1,row,1,col,val,INSERT_VALUES);
>> I hope it helps
>> Gianluca
> hello Gianluca, thanks for re.
> your sugestion doesn't work.
> my code
> Mat xx;
> PetscInitialize(&argc,&argv,(char *)0,help);
> MatCreateSeqAIJ(PETSC_COMM_SELF,5,5,PETSC_DECIDE,PETSC_NULL,&xx);
> PetscInt row [] ={0, 1, 2, 3, 4};
> PetscInt col [] = {1, 0, 4, 2, 3};
> PetscScalar val[] = {1.1,2.2,3.3,4.4,5.5};
> MatSetValues(xx,5,row,5,col,val,INSERT_VALUES);
> MatAssemblyBegin(xx,MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(xx,MAT_FINAL_ASSEMBLY);
> MatView(xx,PETSC_VIEWER_STDOUT_WORLD);
> PetscFinalize();
> and here few examples of results
> row 0: (1, 1.1)
> row 1:
> row 2:
> row 3:
> row 4:
> MatSetValues(xx,5,row,1,col,val,INSERT_VALUES);
> row 0: (1, 1.1)
> row 1: (1, 2.2)
> row 2: (1, 3.3)
> row 3: (1, 4.4)
> row 4: (1, 5.5)
> row 0: (0, 2.2) (1, 1.1) (2, 4.4) (3, 5.5) (4, 3.3)
> row 1: (0, 4.94066e-324) (1, 2.07411e-317) (2, 1.4822e-323) (3,
> 2.07356e-317) (4, 4.24399e-314)
> row 2: (0, 6.36599e-314) (1, 2.122e-314) (2, 2.07402e-317) (3,
> 1.5957e-316) (4, 1.18832e-312)
> row 3: (0, 6.95332e-310) (1, 2.07367e-317) (2, 0) (3, 1.20407e-312) (4,
> 0)
> row 4: (0, 6.95332e-310) (1, 0) (2, 2.07378e-317) (3, 0) (4, 2.122e-314)
> tom
> # tomjan at jay.au.poznan.pl #
> # jay.au.poznan.pl/~tomjan/ #
>> I hope it helps
>> Gianluca
>> On 8 March 2011 09:39, Tomasz Jankowski <tomjan at jay.au.poznan.pl> wrote:
>>> hello,
>>> Could someone give me a hand with MatSetValues function?
>>> suppose such example sparse matrix
>>> 0 1.1 0 0 0
>>> 2.2 0 0 0 0
>>> 0 0 0 0 3.3
>>> 0 0 4.4 0 0
>>> 0 0 0 5.5 0
>>> after storing it in row, col and val arrays we have
>>> row[0] = 0;col[0]=1;val[0]=1.1;
>>> row[1] = 1;col[1]=0;val[1]=2.2;
>>> row[2] = 2;col[2]=4;val[2]=3.3;
>>> row[3] = 3;col[3]=2;val[3]=4.4;
>>> row[3] = 4;col[3]=3;val[4]=5.5;
>>> question is: how to use MatSetValues with it?
>>> I thought that 'MatSetValues(xx,5,row,1,col,val,INSERT_VALUES);' would be
>>> good but it doesn't .(I suppose I don't fully anderstand how it works...)
>>> thanks,
>>> tom
>> "[Je pense que] l'homme est un monde qui vaut des fois les mondes et
>> que les plus ardentes ambitions sont celles qui ont eu l'orgueil de
>> l'Anonymat" -- Non omnibus, sed mihi et tibi
>> Amedeo Modigliani
Amedeo Modigliani
