[petsc-users] Not getting scalability.
Gaurish Telang gaurish108 at gmail.com
Mon Mar 7 08:20:31 CST 2011
I have been testing PETSc's scalability on clusters for matrices of sizes
2000, 10,000, uptill 60,000.
All I did was try to solve Ax=b for these matrices. I found that the
solution time dips if I use upto 16 or 32 processors. However for a larger
number of processors however the solution time seems to go up rather than
down. IS there anyway I can make my code strongly scalable ?
I am measuring the total time (sec) and KSP_SOLVE time in the -log_summary
output. Both times show the same behaviour described above.
Gaurish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110307/d6f100be/attachment.htm>
