[petsc-users] Calling convention from windows VC++ and IFC
Alexander Grayver agrayver at gfz-potsdam.de
Thu Mar 3 12:53:33 CST 2011
Thanks Satish,
I've tried that. Still doesn't work. The same error. Probably changes
were not applied properly.
I built PETSc without any -Gz and sent logs to petsc-maint at mcs.anl.gov
Errors now are the same as in the first message of the thread.
Alexander
On 03.03.2011 18:01, Satish Balay wrote:
> You can try adding the following to
> /cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/include/petscconf.h
> and rebuild the libraries [witout rerunning configure] and
> see if the fortran examples work.
> #ifndef PETSC_STDCALL
> #define PETSC_STDCALL __stdcall
> #endif
> Ideally configure should set this if -Gz was specified to CC aswell -
> but changing CFLAGS is tricky on windows, and there is no equivalent
> of CXX_CXXFLAGS - so the alternative would be COPTFLAGS.
> However you could try the default build [witout any -Gz] - and send
> all the logs to petsc-maint - and we can try figuring out the issue.
> Satish
> On Thu, 3 Mar 2011, Alexander Grayver wrote:
>> Really! Thanks Satish. Errors apparently are different when I use stdcall
>> convention for compiling instead of default one. But the question is how to
>> combine these interfaces now?
>> On 03.03.2011 16:48, Satish Balay wrote:
>>> Oh - I see that with --CXX_CXXFLAGS=-Gz - you get different errors - not
>>> blaslapack errors.
>>>>>>> libpetsc.lib(fuser.o) : error LNK2019: unresolved external symbol
>>>>>>> __imp_GetUserNameA referenced in function "int __cdecl
>>>>>>> PetscGetUserName(char *
>>>>>>> const,unsigned__int64)" (?PetscGetUserName@@YAHQEAD_K at Z)
>>> This is due to compiling C interface with -Gz - so now fortran
>>> interface is unable to link with the c interface.
>>> Satish
>>> On Thu, 3 Mar 2011, Satish Balay wrote:
>>>> Currently I don't have access to ifort to try.
>>>> For one - its strange that c/c++ examples work - but not fortran - esp
>>>> because all blas calls are from the same c/c++ PETSc code.
>>>> One thing you can try:
>>>> cd src/ksp/ksp/examples/tutorials
>>>> make ex2
>>>> make ex2f
>>>> [if ex2 works and ex2f fails - edit makefile - and change target ex2f:
>>>> from using FLINKER to CLINKER and see if it makes a difference]
>>>> Satish
>>>>> Actually, I've added this flag after sending first message to mailing
>>>>> list
>>>>> (sorry for inconveniences) because I though it could help, unfortunately
>>>>> it
>>>>> didn't.
>>>>> The problem probably could be reproduced compiling petsc using
>>>>> --with-clanguage=cxx and VC++ and then trying to run FORTRAN examples.
>>>>> On 03.03.2011 16:26, Satish Balay wrote:
>>>>>> perhaps you can remove '--CXX_CXXFLAGS=-Gz' and retry.
>>>>>> Satish
>>>>>>> I've sent them, thanks!
>>>>>>> I also must note that this is a problem for fortran examples only!
>>>>>>> Because
>>>>>>> when I've done "make  test" after building the situation was:
>>>>>>> mt at agrayver /cygdrive/d/dev/petsc-3.1-p7
>>>>>>> $ make PETSC_DIR=/cygdrive/d/dev/petsc-3.1-p7
>>>>>>> PETSC_ARCH=cygwin-cxx-debug
>>>>>>> test
>>>>>>> Running test examples to verify correct installation
>>>>>>> C/C++ example src/snes/examples/tutorials/ex19 run successfully with
>>>>>>> 1 MPI
>>>>>>> process
>>>>>>> 2 MPI
>>>>>>> processes
>>>>>>> --------------Error detected during compile or
>>>>>>> link!-----------------------
>>>>>>> See
>>>>>>> http://www.mcs.anl.gov/petsc/petsc-2/documentation/troubleshooting.html
>>>>>>> /cygdrive/d/dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c  -MT -Z7
>>>>>>> -fpp
>>>>>>> -I/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/include
>>>>>>> -I/cygdrive/d/dev/petsc-3.1-p7/include
>>>>>>> -I/cygdrive/d/Dev/HPC_2008_SDK/Include
>>>>>>> -I/cygdrive/d/Dev/HPC_2008_SDK/Include    -o ex5f.o ex5f.F
>>>>>>> /cygdrive/d/dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -MT -Z7 -fpp
>>>>>>> -o
>>>>>>> ex5f
>>>>>>> ex5f.o -L/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/lib
>>>>>>> -L/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/lib -lpetsc
>>>>>>> -L/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/lib -lflapack
>>>>>>> -lfblas
>>>>>>> /cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib
>>>>>>> /cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib Gdi32.lib
>>>>>>> User32.lib
>>>>>>> Advapi32.lib Kernel32.lib Ws2_32.lib
>>>>>>> libpetsc.lib(win32draw.o) : error LNK2019: unresolved external
>>>>>>> symbol
>>>>>>> __imp_ReleaseDC referenced in function "int __cdecl
>>>>>>> PetscDrawSetDoubleBuffer_Win32(struct_p_PetscDraw *)"
>>>>>>> (?PetscDrawSetDoubleBuffer_Win32@@YAHPEAU_p_PetscDraw@@@Z)
>>>>>>> symbol
>>>>>>> __imp_BitBlt referenced in function "int __cdecl
>>>>>>> PetscDrawSetDoubleBuffer_Win32(struct _p_PetscDraw *)"
>>>>>>> symbol
>>>>>>> __imp_ExtFloodFill referenced in function "int __cdecl
>>>>>>> symbol
>>>>>>> __imp_SelectObject referenced in function "int __cdecl
>>>>>>> symbol
>>>>>>> __imp_CreateCompatibleBitmap referenced in function "int __cdecl
>>>>>>> symbol
>>>>>>> __imp_CreateCompatibleDC referenced in function "int __cdecl
>>>>>>> symbol
>>>>>>> __imp_GetDC referenced in function "int __cdecl
>>>>>>> symbol
>>>>>>> __imp_UpdateWindow referenced in function "int __cdecl
>>>>>>> PetscDrawRectangle_Win32(struct _p_PetscDraw
>>>>>>> *,double,double,double,double,int,int,int,int)"
>>>>>>> (?PetscDrawRectangle_Win32@@YAHPEAU_p_PetscDraw@@NNNNHHHH at Z)
>>>>>>> On 03.03.2011 14:49, Satish Balay wrote:
>>>>>>>> can you send the corresponding configure.log and make.log to
>>>>>>>> petsc-maint at mcs.anl.gov?
>>>>>>>> Satish
>>>>>>>>> Hello,
>>>>>>>>> I built PETSc-3.1 using VC++ 2008 and IFC 10.1 with the
>>>>>>>>> following
>>>>>>>>> configuration line:
>>>>>>>>> ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe
>>>>>>>>> ifort'
>>>>>>>>> --with-cxx='win32fe cl'  --download-f-blas-lapack=1
>>>>>>>>> --with-precision=double
>>>>>>>>> --with-scalar-type=complex --with-clanguage=cxx
>>>>>>>>> --with-mpi-include="/cygdrive/d/Dev/HPC_2008_SDK/Include"
>>>>>>>>> --with-mpi-lib=["/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib","/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib"]
>>>>>>>>> --useThreads=0 --with-shared=0
>>>>>>>>> Note there is C++ as main language.
>>>>>>>>> Now, when I'm trying to build examples I always get similar
>>>>>>>>> errors:
>>>>>>>>> Error    2     error LNK2019: unresolved external symbol ZGESVD
>>>>>>>>> referenced
>>>>>>>>> in
>>>>>>>>> KSPComputeExtremeSingularValues_GMRES(struct
>>>>>>>>> _p_KSP
>>>>>>>>> *,double *,double *)"
>>>>>>>>> (?KSPComputeExtremeSingularValues_GMRES@@YAHPEAU_p_KSP@@PEAN1 at Z)
>>>>>>>>> libpetsc.lib
>>>>>>>>> Error    3     error LNK2019: unresolved external symbol ZGEEV
>>>>>>>>> referenced
>>>>>>>>> in
>>>>>>>>> function "int __cdecl KSPComputeEigenvalues_GMRES(struct _p_KSP
>>>>>>>>> *,int,double
>>>>>>>>> *,double *,int *)"
>>>>>>>>> (?KSPComputeEigenvalues_GMRES@@YAHPEAU_p_KSP@@HPEAN1PEAH at Z)
>>>>>>>>> libpetsc.lib
>>>>>>>>> Error    4     error LNK2001: unresolved external symbol ZGEEV
>>>>>>>>> libpetsc.lib
>>>>>>>>> Error    5     error LNK2019: unresolved external symbol DZNRM2
>>>>>>>>> referenced
>>>>>>>>> in
>>>>>>>>> function "int __cdecl VecNorm_MPI(struct _p_Vec *,enum
>>>>>>>>> NormType,double
>>>>>>>>> (?VecNorm_MPI@@YAHPEAU_p_Vec@@W4NormType@@PEAN at Z)
>>>>>>>>> libpetsc.lib
>>>>>>>>> Error    6     error LNK2001: unresolved external symbol DZNRM2
>>>>>>>>> libpetsc.lib
>>>>>>>>> Error    7     error LNK2019: unresolved external symbol DZASUM
>>>>>>>>> referenced
>>>>>>>>> in
>>>>>>>>> function "int __cdecl VecNorm_Seq(struct _p_Vec *,enum
>>>>>>>>> NormType,double
>>>>>>>>> (?VecNorm_Seq@@YAHPEAU_p_Vec@@W4NormType@@PEAN at Z)
>>>>>>>>> libpetsc.lib
>>>>>>>>> It look like calling conventions are in disagreement. Any ideas?
>>>>>>>>> May
>>>>>>>>> be I
>>>>>>>>> should specify conventions myself in configuration line? If so,
>>>>>>>>> how to
>>>>>>>>> do
>>>>>>>>> that?
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110303/683499c0/attachment-0001.bin>
