[petsc-users] Calling convention from windows VC++ and IFC
Alexander Grayver
agrayver at gfz-potsdam.de
Thu Mar 3 09:50:42 CST 2011
Really! Thanks Satish. Errors apparently are different when I use
stdcall convention for compiling instead of default one. But the
question is how to combine these interfaces now?
On 03.03.2011 16:48, Satish Balay wrote:
> Oh - I see that with --CXX_CXXFLAGS=-Gz - you get different errors - not blaslapack errors.
>>>>> libpetsc.lib(fuser.o) : error LNK2019: unresolved external symbol
>>>>> __imp_GetUserNameA referenced in function "int __cdecl
>>>>> PetscGetUserName(char *
>>>>> const,unsigned__int64)" (?PetscGetUserName@@YAHQEAD_K at Z)
> This is due to compiling C interface with -Gz - so now fortran
> interface is unable to link with the c interface.
> Satish
> On Thu, 3 Mar 2011, Satish Balay wrote:
>> Currently I don't have access to ifort to try.
>> For one - its strange that c/c++ examples work - but not fortran - esp
>> because all blas calls are from the same c/c++ PETSc code.
>> One thing you can try:
>> cd src/ksp/ksp/examples/tutorials
>> make ex2
>> make ex2f
>> [if ex2 works and ex2f fails - edit makefile - and change target ex2f:
>> from using FLINKER to CLINKER and see if it makes a difference]
>> Satish
>> On Thu, 3 Mar 2011, Alexander Grayver wrote:
>>> Actually, I've added this flag after sending first message to mailing list
>>> (sorry for inconveniences) because I though it could help, unfortunately it
>>> didn't.
>>> The problem probably could be reproduced compiling petsc using
>>> --with-clanguage=cxx and VC++ and then trying to run FORTRAN examples.
>>> On 03.03.2011 16:26, Satish Balay wrote:
>>>> perhaps you can remove '--CXX_CXXFLAGS=-Gz' and retry.
>>>> Satish
>>>>> I've sent them, thanks!
>>>>> I also must note that this is a problem for fortran examples only! Because
>>>>> when I've done "make test" after building the situation was:
>>>>> mt at agrayver /cygdrive/d/dev/petsc-3.1-p7
>>>>> $ make PETSC_DIR=/cygdrive/d/dev/petsc-3.1-p7 PETSC_ARCH=cygwin-cxx-debug
>>>>> test
>>>>> Running test examples to verify correct installation
>>>>> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI
>>>>> process
>>>>> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2 MPI
>>>>> processes
>>>>> --------------Error detected during compile or
>>>>> link!-----------------------
>>>>> See
>>>>> http://www.mcs.anl.gov/petsc/petsc-2/documentation/troubleshooting.html
>>>>> /cygdrive/d/dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -c -MT -Z7 -fpp
>>>>> -I/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/include
>>>>> -I/cygdrive/d/dev/petsc-3.1-p7/include
>>>>> -I/cygdrive/d/Dev/HPC_2008_SDK/Include
>>>>> -I/cygdrive/d/Dev/HPC_2008_SDK/Include -o ex5f.o ex5f.F
>>>>> /cygdrive/d/dev/petsc-3.1-p7/bin/win32fe/win32fe ifort -MT -Z7 -fpp -o
>>>>> ex5f
>>>>> ex5f.o -L/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/lib
>>>>> -L/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/lib -lpetsc
>>>>> -L/cygdrive/d/dev/petsc-3.1-p7/cygwin-cxx-debug/lib -lflapack -lfblas
>>>>> /cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib
>>>>> /cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib Gdi32.lib User32.lib
>>>>> Advapi32.lib Kernel32.lib Ws2_32.lib
>>>>> libpetsc.lib(win32draw.o) : error LNK2019: unresolved external symbol
>>>>> __imp_ReleaseDC referenced in function "int __cdecl
>>>>> PetscDrawSetDoubleBuffer_Win32(struct_p_PetscDraw *)"
>>>>> (?PetscDrawSetDoubleBuffer_Win32@@YAHPEAU_p_PetscDraw@@@Z)
>>>>> __imp_BitBlt referenced in function "int __cdecl
>>>>> PetscDrawSetDoubleBuffer_Win32(struct _p_PetscDraw *)"
>>>>> __imp_ExtFloodFill referenced in function "int __cdecl
>>>>> __imp_SelectObject referenced in function "int __cdecl
>>>>> __imp_CreateCompatibleBitmap referenced in function "int __cdecl
>>>>> __imp_CreateCompatibleDC referenced in function "int __cdecl
>>>>> __imp_GetDC referenced in function "int __cdecl
>>>>> __imp_UpdateWindow referenced in function "int __cdecl
>>>>> PetscDrawRectangle_Win32(struct _p_PetscDraw
>>>>> *,double,double,double,double,int,int,int,int)"
>>>>> (?PetscDrawRectangle_Win32@@YAHPEAU_p_PetscDraw@@NNNNHHHH at Z)
>>>>> On 03.03.2011 14:49, Satish Balay wrote:
>>>>>> can you send the corresponding configure.log and make.log to
>>>>>> petsc-maint at mcs.anl.gov?
>>>>>> Satish
>>>>>>> Hello,
>>>>>>> I built PETSc-3.1 using VC++ 2008 and IFC 10.1 with the following
>>>>>>> configuration line:
>>>>>>> ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe ifort'
>>>>>>> --with-cxx='win32fe cl' --download-f-blas-lapack=1
>>>>>>> --with-precision=double
>>>>>>> --with-scalar-type=complex --with-clanguage=cxx
>>>>>>> --with-mpi-include="/cygdrive/d/Dev/HPC_2008_SDK/Include"
>>>>>>> --with-mpi-lib=["/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpi.lib","/cygdrive/d/Dev/HPC_2008_SDK/Lib/amd64/msmpifec.lib"]
>>>>>>> --useThreads=0 --with-shared=0
>>>>>>> Note there is C++ as main language.
>>>>>>> Now, when I'm trying to build examples I always get similar errors:
>>>>>>> Error 2 error LNK2019: unresolved external symbol ZGESVD
>>>>>>> referenced
>>>>>>> in
>>>>>>> function "int __cdecl KSPComputeExtremeSingularValues_GMRES(struct
>>>>>>> _p_KSP
>>>>>>> *,double *,double *)"
>>>>>>> (?KSPComputeExtremeSingularValues_GMRES@@YAHPEAU_p_KSP@@PEAN1 at Z)
>>>>>>> libpetsc.lib
>>>>>>> Error 3 error LNK2019: unresolved external symbol ZGEEV
>>>>>>> referenced
>>>>>>> in
>>>>>>> function "int __cdecl KSPComputeEigenvalues_GMRES(struct _p_KSP
>>>>>>> *,int,double
>>>>>>> *,double *,int *)"
>>>>>>> (?KSPComputeEigenvalues_GMRES@@YAHPEAU_p_KSP@@HPEAN1PEAH at Z)
>>>>>>> libpetsc.lib
>>>>>>> Error 4 error LNK2001: unresolved external symbol ZGEEV
>>>>>>> libpetsc.lib
>>>>>>> Error 5 error LNK2019: unresolved external symbol DZNRM2
>>>>>>> referenced
>>>>>>> in
>>>>>>> function "int __cdecl VecNorm_MPI(struct _p_Vec *,enum NormType,double
>>>>>>> (?VecNorm_MPI@@YAHPEAU_p_Vec@@W4NormType@@PEAN at Z) libpetsc.lib
>>>>>>> Error 6 error LNK2001: unresolved external symbol DZNRM2
>>>>>>> libpetsc.lib
>>>>>>> Error 7 error LNK2019: unresolved external symbol DZASUM
>>>>>>> referenced
>>>>>>> in
>>>>>>> function "int __cdecl VecNorm_Seq(struct _p_Vec *,enum NormType,double
>>>>>>> (?VecNorm_Seq@@YAHPEAU_p_Vec@@W4NormType@@PEAN at Z) libpetsc.lib
>>>>>>> It look like calling conventions are in disagreement. Any ideas? May
>>>>>>> be I
>>>>>>> should specify conventions myself in configuration line? If so, how to
>>>>>>> do
>>>>>>> that?
