[petsc-users] AOCreateBasic is not scaling
Wed Mar 2 16:29:24 CST 2011
On Wed, Mar 2, 2011 at 4:25 PM, M. Scot Breitenfeld <brtnfld at uiuc.edu>wrote:
> Hi,
> First, thanks for the suggestion on using MPISBAIJ for my A matrix, it
> seems to have cut down on my memory and assembly time. For a 1.5 million
> dof problem:
>    # procs:                  2        4        8           16
> Assembly (sec):        245     124      63       86
> Solver (sec):              924     578     326     680
> Memory (GB):          2.5        1.4     .877    .565
> The problem I have is the amount of time it's taking in AOCreateBasic,
> it takes longer then assembling,
>    # procs:                            2        4        8         16
> AOCreateBasic (sec):         .6      347      170     197
> Is there something that I can change or something I can look for that
> might be causing this increase in time as I go from 2 to 4 processors
> (at least it scales from 4 to 8 processors). I read in the archive that
> AOCreateBasic is not meant to be scalable so maybe there is nothing I
> can do.
Yes, this is non-scalable. What are you using it for?
   Matt
> Thanks,
> Scot
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110302/8097571d/attachment.htm>
