[petsc-users] Coupled multi-component problems with TS
Barry Smith
bsmith at mcs.anl.gov
Wed Jun 29 21:08:40 CDT 2011
Jonathan,
You need to switch to PETSc-dev http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html to access the DAE solvers that Jed Brown has developed.
For that you use TSSetIFunction() and TSSetIJacobian() .
Examples in src/ts/examples/tutorials
ex14.c: ierr = TSSetIFunction(ts,THIFunction,thi);CHKERRQ(ierr);
ex15.c: ierr = TSSetIFunction(ts,FormIFunction,&user);CHKERRQ(ierr);
ex17.c: ierr = TSSetIFunction(ts,FormIFunction,&user);CHKERRQ(ierr);
ex18.c: ierr = TSSetIFunction(ts,FormResidual,&user);CHKERRQ(ierr);
ex8.c: ierr = TSSetIFunction(ts,problem->function,problem->data);CHKERRQ(ierr);
all use this functionality.
Good luck and feel free to send more questions once you are going, but I suspect it will be easy for you with this hint.
Barry
On Jun 29, 2011, at 6:23 PM, Jonathan Backs wrote:
> Hi,
> I am developing my first application with PETSc in an attempt to solve two coupled non-linear PDEs: (1) Poisson's equation for electric potential with a temperature-dependent electrical conductivity, and (2) the heat diffusion equation with a voltage-dependent thermal conductivity and a voltage-and-temperature-dependent source term (ohmic heating from the electric potential and the temperature-dependent electrical conductivity).
> So far I have solved the two problems separately without problems: Poisson's equation with a voltage-dependent electric conductivity (no timestepping), and the heat equation with a temperature-dependent thermal conductivity (timestepping, but no source term; the heat came from the boundary conditions in this case). However, I am not sure how to set up PETSc for solving these non-linear equations simultaneously. For example, when setting up a non-linear problem with time stepping, I understand I have to set the RHSFunction and RHSJacobian, assuming the left hand side provided by PETSc is the time-derivative of the independent variable; When setting up a non-linear problem without time stepping, I understand I have to set the Function assuming a zero left hand side (and then set the Jacobian according to the Function).
> I have tried to implement the coupled problem using a three-dimensional DA with two degrees of freedom (V and T). While PETSc seems to facilitate the use of multiple degrees of freedom in the same RHSFunction (and RHSJacobian), I cannot assign an RHSFunction for the Poisson's equation since the Poisson's equation does not include a time derivative. I have not been able to find any examples in the documentation or on this mailing list that illustrated this particular type of problem.
> Could anyone offer a hint as to the proper strategy for implementing this coupled system of PDEs?
> Thank you for your time,
> Jon
