[petsc-users] Size of off-diagonal matrix
Jed Brown jed at 59A2.org
Thu Jun 23 10:17:13 CDT 2011
On Thu, Jun 23, 2011 at 17:09, John Fettig <john.fettig at gmail.com> wrote:
> Is there any way to access the map from global numbering to the
> compressed numbering?
1. Certainly not before you create the matrix.
2. You have this information in some form if you can call
MatCreateMPIAIJWithArrays(). Scan through the whole local block and make a
sorted list of all the off-process entries. Then scan through again and look
up each off-process entry in that sorted list to get its index.
3. But this is a waste of time, just call MatCreateMPIAIJWithArrays() or
(better) use MatSetValues().
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110623/22a428a4/attachment.htm>
