[petsc-users] SNES_DIVERGED_LS_FAILURE
Juha Jäykkä juhaj at iki.fi
Thu Jun 23 05:18:37 CDT 2011
> Its hard to say anything without knowing what equations are being solved.
I was expecting that, but the equation is rather long to write in ascii. I do
have a latex version somewhere that I can send if necessary. It is horribly
nonlinear, though, including a term like (d/dx f) * (d^2/dx^2) f.
> However,
> does the linear problem converge? If so, you could try continuation in a
> parameter
> in the nonlinear term.
Linear solve is fine, it starts with (SNES iteration 1)
[0] KSPDefaultConverged(): Linear solver has converged. Residual norm
8.93296e-12 is less than relative tolerance 1e-05 times initial right hand
side norm 9.16829 at iteration 1
and goes to (SNES iteration 107 - which is the one which diverges)
4.10794e-06 is less than relative tolerance 1e-05 times initial right hand
side norm 1.07761 at iteration 1
Decreasing ksp_rtol to 1e-15 makes no difference, so I think the problem is
not in the linear solve.
As to the continuation, I was trying to avoid that since I am already doing
continuation in two parameters! That is because I am scanning a 2-dim
parameter space. I know an exact solution for one pair of these two (namely, a
straight line) and then start changing them always using the previous result
as the new initial guess.
I will test the continuation in the worst nonlinear parts and see what
happens.
Cheers,
-Juha
		| Juha Jäykkä, juhaj at iki.fi			|
		| http://www.maths.leeds.ac.uk/~juhaj		|
Name: not available
Desc: This is a digitally signed message part.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110623/f439add8/attachment.pgp>
