[petsc-users] Fwd: superlu_dist with same_nonzero_pattern
Hong Zhang
hzhang at mcs.anl.gov
Wed Jun 22 13:06:31 CDT 2011
Xiangdong :
Does it hangs inside superlu_dist?
Try runtime option '-mat_superlu_dist_equil NO'
If you can send us a stand-alone short code or your matrix in petsc
binary format that repeats this behavior, then we can investigate it.
Likely memory problem.
Hong
> Hello everyone,
> I had some problem in using superlu_dist with same_nonzero_pattern.
> Sometimes superlu_dist solver halts there and never finishes. However,
> when I switched to different_nonzero_pattern or other solvers, the
> program works nicely. Ding had reported this problem a few months
> ago:
> http://lists.mcs.anl.gov/pipermail/petsc-users/2011-January/007623.html
> Following Barry's suggestion, I checked that the nonzero pattern of my
> matrix is still the same via
> ierr=MatSetOption(M, MAT_NEW_NONZERO_LOCATION_ERR,PETSC_TRUE); CHKERRQ(ierr);
> I tried two other options:
> 1 First install the latest superlu_dist (v2.5), then compile petsc
> with this new superlu_dist package. However, the problem is still
> there, and the performance is even worse ( comparing to the option
> --download-superlu_dist=yes (v2.4)).
> 2 I compiled petsc-dev with --download-superlu_dist. However, I got
> some errors when compiling my program with petsc-dev. It said that
> ResonatorOpt.c: In function ‘main’:
> ResonatorOpt.c:154: error: ‘MAT_SOLVER_SUPERLU_DIST’ undeclared (first
> use in this function)
> ResonatorOpt.c:154: error: (Each undeclared identifier is reported only once
> ResonatorOpt.c:154: error: for each function it appears in.)
> Besides superlu_dist, MAT_SOLVER_PASTIX and MAT_SOLVER_PASTIX are
> undeclared either. Am I missing some header files? I used the same
> procedure as I complied regular petsc, which had no such problems. (I
> tried to attach the configure log in a previous mail, but it is
> bounced back.)
> Can you give me some suggestions on using superlu_dist with
> same_nonzero_pattern? Thank you.
> Best,
> Xiangdong
