[petsc-users] Attaching to gdb within screen
Jed Brown
jed at 59A2.org
Wed Jun 22 09:48:39 CDT 2011
On Wed, Jun 22, 2011 at 16:40, John Fettig <john.fettig at gmail.com> wrote:
> I did try using the command line options only (unset $PETSC_OPTIONS
> and used a petsc example), and that has the same problem. If I only
> run the command
> screen -X -S debug screen redirect.sh gdb
> It loads a new window in screen without issue.
What command line does it report using for that?
> So something funky is
> happening inside petsc.
Does the executable path include any special characters or spaces?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110622/ed380a36/attachment-0001.htm>
