[petsc-users] Ghost communication
Milan Mitrovic milanm at student.ethz.ch
Wed Jun 22 04:45:10 CDT 2011
Hello everyone,
I'm trying to use petsc with ppm and here is what I have so far:
First I create parallel vectors with ghost locations using an existing
array that already holds the data:
          CALL VecCreateGhostWithArray(PETSC_COMM_WORLD, &
               Particles%Npart,                          &
               PETSC_DECIDE,                             &
               Particles%Mpart-Particles%Npart,         &
               gi(Particles%Npart:Particles%Mpart),    &
               wp, petsc_vector, info)
where gi is the global indexing, wp is the existing data array, Npart
is the number of real, and Mpart the number of real+ghost particles.
Then, I create a matrix shell, and provide my own multiplication
routine (this part works fine I think).
Inside the multiplication routine I do this:
          CALL VecGhostUpdateBegin(from,INSERT_VALUES,SCATTER_FORWARD,info)
          CALL VecGhostUpdateEnd(from,INSERT_VALUES,SCATTER_FORWARD,info)
          ! get ghosted versions of vectors
          CALL VecGhostGetLocalForm(from,xl,info)
          CALL VecSet(to,0.0_MK,info)
          ! get arrays from petsc vectors
          CALL VecGetArray(xl,xx,xxi,info)
          CALL VecGetArray(to,yy,yyi,info)
Then I modify the data, and do the following:
          CALL VecRestoreArray(xl,xx,xxi,info)
          CALL VecRestoreArray(to,yy,yyi,info)
          ! release local form of vectors
          CALL VecGhostRestoreLocalForm(from,xl,info)
          CALL VecGhostUpdateBegin(to,ADD_VALUES,SCATTER_REVERSE,info)
          CALL VecGhostUpdateEnd(to,ADD_VALUES,SCATTER_REVERSE,info)
And then I call KSP solve:
  call KSPCreate(PETSC_COMM_WORLD, ksp, info)
  call KSPSetOperators(ksp, A, A, DIFFERENT_NONZERO_PATTERN, info)
  call KSPSolve(ksp, b, x, info)
I noticed that the values of the ghost particles never change. The
communication never seems to take place...
Can you give me some hints on what to try? Or what I do wrong?
Thanks!
Milan Mitrovic
