[petsc-users] MatSetValues and Zero enteries
Mon Jun 20 18:20:48 CDT 2011
On Mon, Jun 20, 2011 at 11:16 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
> Matt,
> I see. Please forgive my ignorance, but I don't quite understand why you
> should not be able to set a tolerance for it. Could you please point me to
> the source file that applies the MAT_IGNORE_ZERO_ENTRIES option to the
> matrix? I may be able to manually modify it.
src/mat/impls/aij/seq/aij.c. Search for ignorezeroentries. I think changing
it here would be bad design. Its simple
to process your input matrix to MatSetValues() to chop small values to 0.0
   Matt
> Thanks,
> Mohammad
> On Mon, Jun 20, 2011 at 2:34 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Mon, Jun 20, 2011 at 9:31 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>> Thanks John -- taht's helpful. Do you also know how I can change the
>>> tolerance for dropping elements?
>> Right now, this only discards entires which are exactly floating point
>> 0.0.
>>    Matt
>>> Mohammad
>>> On Mon, Jun 20, 2011 at 1:12 PM, John Mousel <john.mousel at gmail.com>wrote:
>>>> See the matrix options available in the man pages. I think the function
>>>> below is what you are looking for.
>>>> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatSetOption.html
>>>> MatSetOption <http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatSetOption.html#MatSetOption>(A,MAT_IGNORE_ZERO_ENTRIES,PETSC_TRUE <http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Sys/PETSC_TRUE.html#PETSC_TRUE>);
>>>> Best Regards,
>>>> John
>>>> On Mon, Jun 20, 2011 at 2:42 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>>>> Hi folks,
>>>>> I've noticed that MatSetValues explicitly inserts zeros in the matrix
>>>>> if an element is really zero. Is there a way to drop elements (or not save
>>>>> them in the first place) that are below a certain tolerance? I realize one
>>>>> way of doing it is in the application code and when using MatSetValues but
>>>>> I'm just wondering if PETSc has a function for it?
>>>>> Thanks,
>>>>> Mohammad
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110620/0f2323c1/attachment.htm>
